Remove bearings
Joeymf
Remove bearings
Post by Joeymf »
What’s a good way to get this off came off with it when splitting the case
kdxdazz
Country: thailand
Been thanked: 41 times
Re: Remove bearings
Post by kdxdazz »
Half moon style bearing puller, I don't know the correct terminology
Has thanked: 43 times
Been thanked: 110 times
Re: Remove bearings
kdxdazz:
are you describing this (2 photos)? Some people call this a bearing splitter.
Screenshot_20240910_191619_Free Adblocker Browser.jpg (45.01 KiB) Viewed 5786 times
Screenshot_20240910_191532_Free Adblocker Browser.jpg (187.86 KiB) Viewed 5786 times
Joeymf
Re: Remove bearings
Post by Joeymf »
You sure that’s gonna work what’s a different method if it don’t flat head with a hammer ??
Re: Remove bearings
bearing puller
You can usually get one on loan from a chain auto parts store.
Don't use a screwdriver and hammer.
I suggest you watch a bunch of videos on this stuff to educate yourself. Crankshafts are expensive. Other parts are also.
Joeymf
Re: Remove bearings
Post by Joeymf »
Ok thank you
Has thanked: 6 times
Been thanked: 3 times
Re: Remove bearings
Can you feel or detect any vertical play in the big end rod bearing? Side to side play is normal but should be measured anyway with a feeler guage.
Joeymf
Re: Remove bearings
Post by Joeymf »
Yes side to side play no up and down and it should be fine
Joeymf
Re: Remove bearings
Post by Joeymf »
Ima just have it inspected at a shop
Joeymf
Re: Remove bearings
Post by Joeymf »
Yea never mind ima run it how it is I’m already spending too much money
Re: Remove bearings
No vertical play in the rod, I would run it.
Joeymf
Re: Remove bearings
Post by Joeymf »
By that you mean up and down play right bc it don’t have that
Re: Remove bearings
Sounds good to go.
Joeymf
Re: Remove bearings
Post by Joeymf »
Can I re use these bearings
Been thanked: 55 times
Re: Remove bearings
No. Always replace your crank bearings after using tools to remove them.
Joeymf
Re: Remove bearings
Post by Joeymf »
So I bought this tool it didn’t work any other way to go about this
Re: Remove bearings
That is the correct type of tool, but that looks like the harbor freight special that is not large enough. I have the Tusk Tool which works great but isn't cheap. You may be able to make yours work by using longer bolts to connect the 2 halves together. Also be liberal with the heat on the bearing.
You can watch video HERE
Re: Remove bearings
Joeymf, sorry to see you are struggling with this. Check that video that bufftester linked above. Like bufftester says, you may be able to make yours work by using longer bolts on the bearing contact plates and/or increasing the standoff lengths. Without a photo from your setup, I can't tell for sure. Additional notes: 1) the Tusk bearing puller costs about $65, and 2) Yes, there is another way. You'd take the crank to a machine shop.
Re: Remove bearings
oh, make the bearing with a paint dab before pulling it so you know which side goes into the case and which side goes against the crank.
