Remove bearings
Joeymf
Remove bearings
What’s a good way to get this off came off with it when splitting the case
- image.jpg (2.21 MiB) Viewed 5827 times
kdxdazz
- Country: thailand
- Been thanked: 41 times
Re: Remove bearings
Half moon style bearing puller, I don't know the correct terminology
- Has thanked: 43 times
- Been thanked: 110 times
Re: Remove bearings
kdxdazz:
are you describing this (2 photos)? Some people call this a bearing splitter.
Joeymf
Re: Remove bearings
You sure that’s gonna work what’s a different method if it don’t flat head with a hammer ??
- Has thanked: 191 times
Re: Remove bearings
bearing puller
You can usually get one on loan from a chain auto parts store.
Don't use a screwdriver and hammer.
I suggest you watch a bunch of videos on this stuff to educate yourself. Crankshafts are expensive. Other parts are also.
Joeymf
- Molly's 70
- Has thanked: 6 times
- Been thanked: 3 times
Re: Remove bearings
Can you feel or detect any vertical play in the big end rod bearing? Side to side play is normal but should be measured anyway with a feeler guage.
Joeymf
Joeymf
Joeymf
- Molly's 70
Re: Remove bearings
No vertical play in the rod, I would run it.
Joeymf
- Molly's 70
Re: Remove bearings
Sounds good to go.
Joeymf
- ss109
- Has thanked: 33 times
- Been thanked: 55 times
Re: Remove bearings
No. Always replace your crank bearings after using tools to remove them.
Joeymf
Re: Remove bearings
So I bought this tool it didn’t work any other way to go about this
- image.jpg (2.76 MiB) Viewed 4924 times
- image.jpg (3.67 MiB) Viewed 4924 times
- Been thanked: 10 times
Re: Remove bearings
That is the correct type of tool, but that looks like the harbor freight special that is not large enough. I have the Tusk Tool which works great but isn't cheap. You may be able to make yours work by using longer bolts to connect the 2 halves together. Also be liberal with the heat on the bearing.
You can watch video HERE
Re: Remove bearings
Joeymf, sorry to see you are struggling with this. Check that video that bufftester linked above. Like bufftester says, you may be able to make yours work by using longer bolts on the bearing contact plates and/or increasing the standoff lengths. Without a photo from your setup, I can't tell for sure. Additional notes: 1) the Tusk bearing puller costs about $65, and 2) Yes, there is another way. You'd take the crank to a machine shop.
Re: Remove bearings
oh, make the bearing with a paint dab before pulling it so you know which side goes into the case and which side goes against the crank.
