I stared at the manual for awhile and found this hole that's not in the manual. I found other differences between my manual and my bike, so maybe this hole is supposed to be there. Anybody can confirm?
The only thing that looks remotely similar to the mysterious part would be a piece of shift rod
Soooo, everything checks out on the outside (set aside the broken bits). Obviously the problem goes deeper cuz when I try to shift (with a socket on the shaft) it gets stuck in between gears, if I rotate the shaft back and forth, it shifts and stays on. So maybe there's more broken pieces inside the case
bummer
I've gone as far as I can on my own, now trip to the mecanic to split the case
Any idea how much $$$$$ I'm in for?
