Quick desription of what happened
I was coming out of the turn and tried to upshift (at least I think) from 2nd to 3rd when I found "neutral".
(note: I find neutral sometimes between 1st and 2nd when riding hard but always thought it was because I wasn't engaging the gear fully)
Anyway, I tried to put it back in gear and it made that weird no, scratch that, WRONG HORRIFYING GRINDING noise like it was between gears...
I stopped and tried to put it back in neutral, and it took me awhile to get there. The engine turns ok, but everytime I try to put it back in gear, it makes a not so good noise so I stopped and a buddy towed me back to the truck.
I drained the oil, there is a bit of sparkly thingy in it
I then checked the shifter and it looks like I can't go up because the shifter hit the case (the part that connect to the spline).
The thing is I did not crash on this side. It seems like the shifter went up on the spline. my boot fits the same when I'm on the pegs though
It's almost like the spline rotated inside the gear box.
Ok, i removed the shifter and re-installed so that it wouldn't hit the case, I can shift ( bike not running) BUT they're harsh and noisy (could be because I haven't refilled the oil, but it's louder and harsher than I would expect) and doesn't look like the gear would stay on, I also have to rock the bike back and forth in order to shift them but I think it's normal when the bike is not runnig.
I don't know if it all makes sense to any of you but that's the best I can describe it.
Sorry for the long confusing post but I feel like I'm in DEEP trouble there, just trying to be as thourough as possible
Please help
Wilf
