Flywheel weight???
- rbates9
- Been thanked: 2 times
Flywheel weight???
I am just looking for some pros and cons of adding a flywheel weight from some of the people that have put one on. I ride mostly pretty steep trails with lots of rocks, roots, and a little mud. My bike has a woods pipe turbine core II and boisen reeds, thats about it for engine up grades. I would like to do the RB carb mods in the future but I am just looking for a little more bottom for right now. Also what weights are available and what seems to work the best?
- Griffbones
A FWW will not add any power, it will only tame down the hit of a two stroke slightly, and make the bike slightly less apt to stall due to the extra rotating mass. The KDX is already very smooth, I really can't see the need for a flywheel weight myself.
I have used FWW's before, but mainly on MX bikes converted to woods use.
'83 CR60R Fully restored
'97 DR350 (407cc)
2005 KX85 (103.5cc)
2006 KDX 200 (Bone stock other than Jetting, Gnarley woods, Turbine Core II)
2007 250 XC-W (SX head)
'97 DR350 (407cc)
2005 KX85 (103.5cc)
- David_L6
A flywheel weight just makes the motor wind up slower and wind down slower. Slowing down the "winding up" is the "taming the hit" part that you hear everyone talk about. Slowing down the "winding down" is the "helps with stalling" part that you hear everyone talking about. A flywheel weight may do what you want but so would shifting and clutching. Sounds to me like what would really do what you want is one of those auto clutches. I'm seriously considering a Revlok clutch for my KDX 200 just to make it easier for my daughter and my son's girlfriend to ride when they ride with us.
- kawagumby
- Been thanked: 3 times
A flywheel weight helps control wheelspin where traction is lacking if you have an engine capable of breaking traction. Shifting and clutching may help some as will throttle control to some extent, but even holding an even throttle won't help if the traction is uneven and your rear wheel is hopping around. If you need every option, like when riding a rocky uphill or navigating through slimey roots, etc., the extra flywheel weight will help. If your plastic looks like crap after a few rides, your probably the kind of rider who could use a flywheel. If your bike is pretty, and your plastic looks like new even tho you've ridden it for a year, you probably won't need a flywheel.
- ss109
- Has thanked: 34 times
- Been thanked: 59 times
I personally don't feel that a FWW is needed on a KDX. Proper jetting along with choosing the right gear and good throttle/clutch control will get you through, up, or over just about anything. Of course, this is all IMO and YMMV.
The KDX doesn't stall like a MX bike.... I never even considered a FWW.... or auto-clutch.... or...
I think she is about perfect in it's stock form other than suspension and carburation....
- rbates9
I know what a flywheel weight is and what it dose. I was just looking for some input from people who have tried them.... I do realize that it dose not magically make more horse power aper from the sky. But they do give more tractability. If no one on here has tried one that is fine, maybe I could be the first.
- ss109
Go for it. All most of us are saying is that we don't see any reason to add one to a KDX. If you feel you need more low end then try it and see what you think or maybe find yourself a 4t.
- Griffbones
I have run them several times, just not on the KDX, because I don't feel the the KDX needs one IMHO.
If you really want to try one go here http://www.steahlyoffroad.com/
In fact here is a link to their KDX 10 ounce weight. http://www.steahlyoffroad.com/flywheel- ... eight.html
'97 DR350 (407cc)
2005 KX85 (103.5cc)
'97 DR350 (407cc)
2005 KX85 (103.5cc)
- jlove1974
LOL, if you have ever disassembled the engine and taken the flywheel off, you'll know why you don't need a weight. It's already PRE-weighted from the factory. This flywheel weighs ALOT more than a MX-style rotor assembly.
I would think about lightening it more than I would ever think to add weight to this flywheel. It has to weigh a few lbs already
- Mr. Wibbens
I can't imagine not having it, but then again I don't live where it's flat as a pancake
It really helps keeping the motor running going down long steep hills easuer
Another added benefit is that when your motor starts to stall, and it stops making any kind of sound, sometimes you can pull the clutch in fast enough and the bike fires back up
- Griffbones
It sure ain't flat where I ride.Mr. Wibbens wrote:I can't imagine not having it, but then again I don't live where it's flat as a pancake
'97 DR350 (407cc)
2005 KX85 (103.5cc)
'97 DR350 (407cc)
2005 KX85 (103.5cc)
- Been thanked: 19 times
