Flywheel weight???
rbates9
Been thanked: 2 times
Flywheel weight???
Post by rbates9 »
I am just looking for some pros and cons of adding a flywheel weight from some of the people that have put one on. I ride mostly pretty steep trails with lots of rocks, roots, and a little mud. My bike has a woods pipe turbine core II and boisen reeds, thats about it for engine up grades. I would like to do the RB carb mods in the future but I am just looking for a little more bottom for right now. Also what weights are available and what seems to work the best?
Griffbones
Post by Griffbones »
A FWW will not add any power, it will only tame down the hit of a two stroke slightly, and make the bike slightly less apt to stall due to the extra rotating mass. The KDX is already very smooth, I really can't see the need for a flywheel weight myself.
I have used FWW's before, but mainly on MX bikes converted to woods use.
'83 CR60R Fully restored
'97 DR350 (407cc)
2005 KX85 (103.5cc)
2006 KDX 200 (Bone stock other than Jetting, Gnarley woods, Turbine Core II)
2007 250 XC-W (SX head)
rbates9
Post by rbates9 »
I didn't expect it to "add" power, just help with the lug on the bottom. Maybe maintain a little more rpm when she is lugging. Most of what I ride is half throttle or less.
David_L6
Post by David_L6 »
A flywheel weight just makes the motor wind up slower and wind down slower. Slowing down the "winding up" is the "taming the hit" part that you hear everyone talk about. Slowing down the "winding down" is the "helps with stalling" part that you hear everyone talking about. A flywheel weight may do what you want but so would shifting and clutching. Sounds to me like what would really do what you want is one of those auto clutches. I'm seriously considering a Revlok clutch for my KDX 200 just to make it easier for my daughter and my son's girlfriend to ride when they ride with us.
kawagumby
Been thanked: 3 times
Post by kawagumby »
A flywheel weight helps control wheelspin where traction is lacking if you have an engine capable of breaking traction. Shifting and clutching may help some as will throttle control to some extent, but even holding an even throttle won't help if the traction is uneven and your rear wheel is hopping around. If you need every option, like when riding a rocky uphill or navigating through slimey roots, etc., the extra flywheel weight will help. If your plastic looks like crap after a few rides, your probably the kind of rider who could use a flywheel. If your bike is pretty, and your plastic looks like new even tho you've ridden it for a year, you probably won't need a flywheel. :mrgreen:
fuzzy
Post by fuzzy »
Search on here for carb needles and do some reading as well. The needle can drastically change the 'hit'
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
Has thanked: 34 times
Been thanked: 61 times
I personally don't feel that a FWW is needed on a KDX. Proper jetting along with choosing the right gear and good throttle/clutch control will get you through, up, or over just about anything. Of course, this is all IMO and YMMV. :cool:
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
The KDX doesn't stall like a MX bike.... I never even considered a FWW.... or auto-clutch.... or... :mrgreen:
I think she is about perfect in it's stock form other than suspension and carburation....
rbates9
Post by rbates9 »
I know what a flywheel weight is and what it dose. I was just looking for some input from people who have tried them.... I do realize that it dose not magically make more horse power aper from the sky. But they do give more tractability. If no one on here has tried one that is fine, maybe I could be the first.
Go for it. All most of us are saying is that we don't see any reason to add one to a KDX. If you feel you need more low end then try it and see what you think or maybe find yourself a 4t.
Griffbones
I have run them several times, just not on the KDX, because I don't feel the the KDX needs one IMHO.
If you really want to try one go here http://www.steahlyoffroad.com/
In fact here is a link to their KDX 10 ounce weight. http://www.steahlyoffroad.com/flywheel- ... eight.html
'97 DR350 (407cc)
2005 KX85 (103.5cc)
jlove1974
Post by jlove1974 »
LOL, if you have ever disassembled the engine and taken the flywheel off, you'll know why you don't need a weight. It's already PRE-weighted from the factory. This flywheel weighs ALOT more than a MX-style rotor assembly.
I would think about lightening it more than I would ever think to add weight to this flywheel. It has to weigh a few lbs already
Mr. Wibbens
Post by Mr. Wibbens »
I can't imagine not having it, but then again I don't live where it's flat as a pancake
It really helps keeping the motor running going down long steep hills easuer
Another added benefit is that when your motor starts to stall, and it stops making any kind of sound, sometimes you can pull the clutch in fast enough and the bike fires back up
Griffbones
Mr. Wibbens wrote:I can't imagine not having it, but then again I don't live where it's flat as a pancake
It sure ain't flat where I ride. :grin: I just don't see the KDX needing any additional weight personally, but to each his own. I can see why some folks would like it, I just don't want the KDX to rev any slower and I feel it is already ultra smooth. Maybe you guy's with the hot rod mods from RB would find additional weight more useful?
'97 DR350 (407cc)
2005 KX85 (103.5cc)
Been thanked: 19 times
With the rb mods a fww is needed even less I find. The kdx has a heavy flywheel stock.
kawagumby
Post by kawagumby »
Just the opposite with my 220, it hits very hard right off of idle and wheelspin becomes a problem in poor traction. The flywheel is a definite plus.
