Cutting case
KDX220rser
Cutting case
Post by KDX220rser »
how do you guys cut the case for the 17mm kx rod? Its a 15mm hole and needs to be 17mm. Reamer will not do it in one cut. do i need to ream it to 16mm first. of do i need to just drill it will a 17mm bit and ream it to 17mm? does it need to be on a drill press or can i do it will hand drill?
09 KTM 250 XC-W
2005 KX-DX Hybrid
03 Ozark (under construction)
1978 Honda NC50 (under construction)
Tedh98
Been thanked: 2 times
Re: Cutting case
Post by Tedh98 »
KDX220rser wrote:how do you guys cut the case for the 17mm kx rod? Its a 15mm hole and needs to be 17mm. Reamer will not do it in one cut. do i need to ream it to 16mm first. of do i need to just drill it will a 17mm bit and ream it to 17mm? does it need to be on a drill press or can i do it will hand drill?
This is coming from a person that attempts to do everything himself - I'd let a machine shop handle it. I wouldn't trust that you'd be able to set up the engine and secure on a drill press. I defintely wouldn't risk doing it with a hand drill.
Now if you had the cases split and could lay them flat on the drill press table, that would be a different story.
I bought the reamer and the machine shop charged me $40. To me that was well worth it to avoid screwing up the cases. That was the only thing I didn't do with my hybrids.
KDX220rser
Thanks man. Thats what i thought.. I 100% agree with that one..
09 KTM 250 XC-W
2005 KX-DX Hybrid
KarlP
Post by KarlP »
I did mine myself.
I'd let a machine shop do it next time.
