preparing for plating
ogri
Post by ogri »
hiya fellas,hope your all well.i've decided to strip the top end of my bike ('00kdx220) and replate.i've removed the kips and the head studs and while cleaning the cylinder i discovered an allen plug directly below the exhaust port.should this be removed before i send it to the platers? if you are unfamiliar with this plug i will be happy to post a pic.
thanks.
All the platers will do is clean your cylinder and plate the bore... nothing else unless you are getting something fancy.
I do not know what you are talking about on the Allen Plug however....
ogri
Post by ogri »
i believe you have to remove all metalwork.so studs and kips removed,then i discovered this fella.
centre of exhaust post,hollow allen plug.
hopefully its of no consequence but i got the idea all metalwork had to be removed prior to the processes the barrel undergoes.
Little Jeff
Post by Little Jeff »
Who is going to be doing the replating?
Little Jeff
Riding with your buddies and an adventure, riding with certain individuals is an ordeal.
MXOldtimer
Post by MXOldtimer »
Might as well punch it out a little more if your going to plate it.
ogri
Post by ogri »
Little Jeff wrote:Who is going to be doing the replating?
Little Jeff
i live in the uk jeff.a company called langcourts has a great reputation for their work.anyone want to comment about the stud?presumably posters here have left it alone.
Has thanked: 5 times
Been thanked: 12 times
I think you'll be fine leaving that plug in place. I've heard good things about langcourt as well. Make sure to post some pictures of the finished cylinder when you get it back from plating.
J.
fuzzy
Post by fuzzy »
I dont think langcourt will do anything with the ports if you request a bore increase, and increasing bore will alter port timing. In a bad way? Dunno.
Looks just like a freeze/casting plug...No need to mess with it for replate.
ogri
Post by ogri »
just want a replate fellas.thanks for the replies,pot going to langcourts tomorrow.i'llpost a pic on its return juliend.
MXOldtimer
You'll want to buy a new piston prior plating. They will mic the new pistons and make sure the tolerances are correct before/after plating.
That plug's in the water jacket, ain't it? The best source for the correct answer is Langcourt. As unnecessary as removal of a water jacket plug would seem to me...I'm not doing the work. For all I know the electrical charges involved in a replate job fuses all separate metal parts!
Langcourt has a good reputation on this side of the puddle, too.
Don't forget some pics of the finished product!!
Thanks!
sean-svm
Post by sean-svm »
Don't loose that plug as it is not a part you can buy new from Kawasaki.
ogri
Post by ogri »
sean-svm wrote:Don't loose that plug as it is not a part you can buy new from Kawasaki.
hopefully langcourts will leave it in place.if they do remove it i'll make sure its returned to me.
thanks for the replies gents. :supz:
ogri
Post by ogri »
well,got the cylinder back.heres a before and after .
this plug,centre of exhaust port was removed by langcourts and returned with the barrel.
putting a new bottom shock bearing in tomorrow and i'll be ready for the weekend.
:supz:
So...where are the plugs for the subport drum rods?
Seems odd they would replace the one..but not those?
fuzzy
Post by fuzzy »
Wow, did they true up the deck?
KarlP
Post by KarlP »
Check to be sure the right hand subport actuating rod moves smoothly in its bore......
That rod has a o-ring/packing/seal on it that keeps ehaust gasses from blowing by. The plating process can leave the inside of that bore rough and the rod can therefore not move as smothly as it needs to.
The whole KIPS mechanism should move smooth as silk..
ogri
Post by ogri »
KarlP wrote:Check to be sure the right hand subport actuating rod moves smoothly in its bore......
karl,it was rough in there.the left had rod went in easily.i had to clean the right side casting out.i wish now that i had been more thorough as the actuation of the kips felt a little stiffer than before the rebuild.
ogri
Post by ogri »
canyncarvr wrote:So...where are the plugs for the subport drum rods?
if you mean those allen caps plugging the rods in,i removed those.
tried it out today and everything appears fine.should i re-torque the head now its cooled down?
KarlP
Post by KarlP »
I don't think you need to re-torque the head bolts.
Have you observed smooth operation of the KIPS mechanism while the motor is running?
The left hand slotted cover provides a convenient way to do that.
