preparing for plating
ogri
hiya fellas,hope your all well.i've decided to strip the top end of my bike ('00kdx220) and replate.i've removed the kips and the head studs and while cleaning the cylinder i discovered an allen plug directly below the exhaust port.should this be removed before i send it to the platers? if you are unfamiliar with this plug i will be happy to post a pic.
thanks.
thanks.
All the platers will do is clean your cylinder and plate the bore... nothing else unless you are getting something fancy.
I do not know what you are talking about on the Allen Plug however....
ogri
Little Jeff
- MXOldtimer
ogri
- fuzzy
I dont think langcourt will do anything with the ports if you request a bore increase, and increasing bore will alter port timing. In a bad way? Dunno.
Looks just like a freeze/casting plug...No need to mess with it for replate.
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
- MXOldtimer
That plug's in the water jacket, ain't it? The best source for the correct answer is Langcourt. As unnecessary as removal of a water jacket plug would seem to me...I'm not doing the work. For all I know the electrical charges involved in a replate job fuses all separate metal parts!
Langcourt has a good reputation on this side of the puddle, too.
Don't forget some pics of the finished product!!
Thanks!
Thanks!
ogri
ogri
So...where are the plugs for the subport drum rods?
Seems odd they would replace the one..but not those?
KarlP
Check to be sure the right hand subport actuating rod moves smoothly in its bore......
That rod has a o-ring/packing/seal on it that keeps ehaust gasses from blowing by. The plating process can leave the inside of that bore rough and the rod can therefore not move as smothly as it needs to.
The whole KIPS mechanism should move smooth as silk..
'08 KTM200xc
KX100 for the boy
KX100 for the boy
ogri
KarlP wrote:Check to be sure the right hand subport actuating rod moves smoothly in its bore......
karl,it was rough in there.the left had rod went in easily.i had to clean the right side casting out.i wish now that i had been more thorough as the actuation of the kips felt a little stiffer than before the rebuild.
ogri
KarlP
