New Top End Due
- 2001kdx
New Top End Due
I'm on the stock top end on my bike, so it's time to get a new one.
Should I go wiesco, and how much does it cost? I'm hoping it's >$150, cuz money is tight unitl I get a job.
Does this just consist of piston+rings+gaskets and kips cleaning?
- m0rie
Re: New Top End Due
Thats pretty much spot on.2001kdx wrote:I'm on the stock top end on my bike, so it's time to get a new one.
- scheckaet
why do you say you're due for a topend? Any loss in power / compression?
Question for everybody:
How often do you replace rings/piston/gasket? or is this more of a "seat of the pants" feeling?
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- Jeb
If you go with Wiseco here's the whole shootin' match - piston, rings, wrist pin, circlips, top-end gasket kit and needle bearing (upper rod bearing) . . .
$130.50 including shipping. I'm assuming since you're replacing the stocker that you'll be needing a std bore:
http://cgi.ebay.com/ebaymotors/KAWASAKI ... enameZWD1V
Put in a new top bearing, too. Didn't see that on the list.........
When? An '01 in '07 that hasn't had a topend job probably needs one.
Re: 'Every year if you ride a lot'
That would be on the cautious side a tad.
What you see up the exhaust port won't tell you much. If it looks BAD that's one thing...but if it looks GOOD, that doesn't mean much of anything.
What's the plating look like on the intake bridges? For that matter, what does it look like EVERYwhere? What's the blow-by look like on the pin axis? Is the cylinder round?
Don't 'see' any of that gazing up the exhaust port.
- scheckaet
So I guess after 2 years of riding (30 miles a week on average), be a good idea to check things out.Re: 'Every year if you ride a lot'
Alright, I'll probably check it out when I send my head and carb to Ron.
Thanks guys
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- 2001kdx
How about this? I'm out riding today, bike all warmed up, and a few times, I try to go WFO in 2nd or 3rd gear, try for max rpm's, and it stops revving at a certain point - it's as if the kips barely opens.
This has been happening for a few rides, I thought that kips is sticking closed.
I think I'll take the powervalve apart to clean. So... What do I need to buy, just to clean it up, given nothing is broken? I need to pull the jug right?
A head gasket.....
Oh...and muffler bearings.
