New Top End Due
2001kdx
New Top End Due
Post by 2001kdx »
I'm on the stock top end on my bike, so it's time to get a new one.
Should I go wiesco, and how much does it cost? I'm hoping it's >$150, cuz money is tight unitl I get a job.
Does this just consist of piston+rings+gaskets and kips cleaning?
m0rie
Re: New Top End Due
Post by m0rie »
2001kdx wrote:I'm on the stock top end on my bike, so it's time to get a new one.
Thats pretty much spot on.
1989 KDX 200
2007 TTR-50E
scheckaet
Post by scheckaet »
why do you say you're due for a topend? Any loss in power / compression?
Question for everybody:
How often do you replace rings/piston/gasket? or is this more of a "seat of the pants" feeling?
2001kdx
Post by 2001kdx »
* Today I popped the pipe off and the piston didn't look too bad. It might be OK for the moment So I'll hold off on the wiesco.
Jeb
Post by Jeb »
If you go with Wiseco here's the whole shootin' match - piston, rings, wrist pin, circlips, top-end gasket kit and needle bearing (upper rod bearing) . . .
$130.50 including shipping. I'm assuming since you're replacing the stocker that you'll be needing a std bore:
http://cgi.ebay.com/ebaymotors/KAWASAKI ... enameZWD1V
"No farmer ever plowed a field by turning it over in his mind" -George E. Woodbury
CLICK FOR PICS!
AZRickD
Been thanked: 3 times
Post by AZRickD »
Piston and rings every year if you ride a lot?
Rick
2001kdx
Post by 2001kdx »
Thanks Jeb you're a big help.
canyncarvr
Post by canyncarvr »
Put in a new top bearing, too. Didn't see that on the list.........
When? An '01 in '07 that hasn't had a topend job probably needs one.
Re: 'Every year if you ride a lot'
That would be on the cautious side a tad.
What you see up the exhaust port won't tell you much. If it looks BAD that's one thing...but if it looks GOOD, that doesn't mean much of anything.
What's the plating look like on the intake bridges? For that matter, what does it look like EVERYwhere? What's the blow-by look like on the pin axis? Is the cylinder round?
Don't 'see' any of that gazing up the exhaust port.
scheckaet
Post by scheckaet »
So I guess after 2 years of riding (30 miles a week on average), be a good idea to check things out.
Alright, I'll probably check it out when I send my head and carb to Ron.
Thanks guys
2001kdx
Post by 2001kdx »
How about this? I'm out riding today, bike all warmed up, and a few times, I try to go WFO in 2nd or 3rd gear, try for max rpm's, and it stops revving at a certain point - it's as if the kips barely opens.
This has been happening for a few rides, I thought that kips is sticking closed.
I think I'll take the powervalve apart to clean. So... What do I need to buy, just to clean it up, given nothing is broken? I need to pull the jug right?
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
A head gasket.....
Oh...and muffler bearings. :cool:
