Bottom end did not go together. How do I recover?
79440LTD
I am assembling the bottom end on my 1999 KDX220R. I installed the crank bearings with heat and cold. They dropped right in. I installed the crank into one half and it dropped right in with heat and cold. I went to install the other half of the crankcase using the same method and it locked up partway on. How do I recover? Any way to save the bearings and crank? I have a case splitter but would like to save the bearings and the freshly rebuilt and balanced crank if possible. Recommendations? It is going to have to come apart so I can get the Kawibond adhesive off.
- ss109
- Has thanked: 33 times
- Been thanked: 55 times
Re: Bottom end did not go together. How do I recover?
Brand new bearings? I would just use my crank [EDIT: I meant case] splitter and reuse everything. I've done it before on one of my KDX builds with no issue.
79440LTD
Yes, new OEM bearings. Crankworks did the crank with OEM parts as well. I will split, inspect and try again. Thanks for the reply!
- Molly's 70
- Has thanked: 6 times
- Been thanked: 3 times
Your fine. All your parts are just fine. Get that case half back off & try again.
- Been thanked: 19 times
- ss109
Yep, that's the easiest way to go about it.
