Rear axle ID and length
assquatch20
Has thanked: 11 times
Been thanked: 4 times
Post by assquatch20 »
Can anyone tell me the total length on the rear axle and how big the opening is for the hollow part on each side? I won't be around mine for a few days and am trying to figure something out
Kawibunga
Has thanked: 1 time
Been thanked: 25 times
Re: Rear axle ID and length
Post by Kawibunga »
I should be able to have a look tonight......... if I don't forget!
Go Riders!
4 X KDX 220s - 2 KLX 650s
Kawibunga
Has thanked: 1 time
Post by Kawibunga »
Apologies for the late response, hopefully it's not too late! Note that your the threaded side will be pounded out a bit and won't in reality be the same ID as the through bore. Mine measured .485" on one side but probably more like .450" on the threaded side - I drilled it out a bit when I noticed that.......
Go Riders!
Kawibunga
Has thanked: 1 time
Post by Kawibunga »
As well, I didn't convert and nicely round them to metric measurements which I'm sure they were when manufactured......... hopefully this is what you were looking for......
Go Riders!
assquatch20
Kawibunga wrote: 02:56 pm Oct 05 2025 As well, I didn't convert and nicely round them to metric measurements which I'm sure they were when manufactured......... hopefully this is what you were looking for......
That is very helpful. I think I need the length from one end of the hollow part to the other but my bike is still being rebuilt at a buddy's so it may be a week or two. What I'm trying to do is mount a trailer that uses a skewer through the rear axle. The builder makes mounting hardware/skewers for the KLX250 but I think this might be a wider axle, not sure.
What he told me was he needed to know how long the axle was and that it would need to be at least 3/8" inner diameter for the skewer. This tells me the skewer will fit but not positive how long it needs to be yet. Regardless it is greatly appreciated
Kawibunga
Has thanked: 1 time
Post by Kawibunga »
Ahhh - total length, not the inside length, not a problem....... stay tuned!
Go Riders!
Kawibunga
Has thanked: 1 time
Post by Kawibunga »
This should have it covered......
Go Riders!
assquatch20
Kawibunga wrote: 10:42 pm Oct 05 2025 This should have it covered......
This is great, thank you again. I'll verify mine is more or less the same but I'm guessing it'll work. I'll pass this along.
The trailer is a single wheel deal made for single track or touring even. Mine is 30lbs with a 60lb capacity but I think the newer version he builds has better numbers and can be adapted to different lengths now as well. Different skewers or necessary hardware can adapt the trailer from one bike to the next. Might be something some other owners are interested in. They're not cheap but mine seems extremely well built. Kipmoto is the company for those who may be curious. I don't work for them or anything like that. Just decided to get one some years ago now for my tw200
