Kdx 200 shock
1fletch
Country: Uk
Kdx 200 shock
Post by 1fletch »
Hi guys , l am just going through my kdx 2001990 kdx e series that I am fully rebuilding and the rear shock stanchion is corroded badly, has anyone replaced this or had repaired or alternatively swapped the full shock out with a near h series
SpruceItUp
Has thanked: 135 times
Been thanked: 61 times
Re: Kdx 200 shock
Post by SpruceItUp »
I would assume H and E series shocks aren't swappable, given the differences within the two frames. Apparently the springs can be swapped though.
viewtopic.php?t=16754 discusses this.
In terms of your rebuilding question, I have no clue. Rear shock rebuilds are beyond my level at the moment. I've only ever touched front suspensions.
I'm sure the others on the site can give you plenty of good information, though!
Good luck.
'92 KDX200
'25 CRF300L Rally
'05 CR125R
Has thanked: 311 times
Been thanked: 144 times
Re: Kdx 200 shock
You'll be best off searching for a good used shock with the seller verifying that the shaft chrome is in perfect condition, and giving a guarantee on it.
Otherwise you're looking at a custom made shaft, or else a strip / repair rust pits / re-chrome job, whuch you may as well go with a new custom built Race Tech shock at that cost...
Re: Kdx 200 shock
Just look for a used shock with great chrome.
"E" series and the last model (H 200 or A 220R) will not work because the way the pipe runs. The shock reservoir on "E" goes down as the pipe is above it. The last model goes up to clear the pipe that runs under it.
lucy
Re: Kdx 200 shock
Post by lucy »
Try Tom Fleming at: https://www.tfsuspension.com/
Tom has done lots of KDX suspension.
You could also try Jeff Fredette.
Either of those guys might have some suggestions for you.
1fletch
Country: Uk
Re: Kdx 200 shock
Post by 1fletch »
Thanks guys , unfortunately not that many kicking around in the uk although I have had a couple of bits off JF on previous builds and will reach out to him and see what his views are and keep you updated
