Any suggestions?
I'm riding a KX125 frame with a Blaster motor in it and I find the clutch pull pretty stiff. I've got a new cable coming, but I seem to recall some people using a different clutch perch with an easier ratio.
Any remember those? So many hydro clutches out now, i've gotten spoiled. My forearm is aching!
Clutch perch
- Has thanked: 248 times
- Been thanked: 124 times
Re: Clutch perch
Hydraulic clutches don't give you any real benefit that a good lever doesn't give you, it's all about leverage ratios whether it's an actual mechanical lever or whether it's a hydraulic cylinder leverage ratio versus slave cylinder.karlgp wrote: 07:20 pm Jun 23 2025 Any suggestions?
The only benefit you get over a premium Motion Pro T3 Slidelight clutch cable (use CRF250X 2007 for the KDX application) is that cables don't automatically compensate for hot clutch swell the way hydraulic cylinders do. I simply adjust my cable when the bike is up to operating temperature during/after riding, and don't bother adjusting it with the engine cold.
I'm running Flo levers, they might be slightly easier leverage ratio than stock, but I have another one on the shelf that has two cable mounting pull points so obviously one will have a longer handlebar perch lever travel with less (engine side) clutch travel, which will make your lever feel a lot easier. The other cable mounting point will be closer to stock where you have a shorter stroke required during clutch release/engagement, but more force required at the perch.
AS3 or ASV or a Chinese generic I have, one of the three had two different attachment points for the handlebar end of the clutch cable so you can change the leverage. Sorry I don't have a better answer for you.
On the KDX engine, people previously have just cut and lengthened the clutch release arm on the engine / gearbox / clutch case where the cable attaches, adding about 7mm or so of metal to it and welding it back together after cutting it in the middle.
kdxdazz
- Country: thailand
- Been thanked: 41 times
Re: Clutch perch
Remember Molly grease on the pivot points, don't use ordinary grease
karlgp
Re: Clutch perch
Thanks for the info
I'm going to go with this one
https://www.motosport.com/pro-taper-pro ... -X001-Y001
It'll sure be better than what I got!
Re: Clutch perch
karlgp wrote: 10:11 pm Jun 24 2025 Thanks for the info
Hey that thing is quite nice! Sealed bearing pivot!?!
karlgp
Re: Clutch perch
Much better than the floppy old lever that was on there
I moved the motor end cable mount a little and the lever assembly has an adjustment for "at rest" position
Old, worn out forearms appreciate it!
