Excessive head cylinder splooge
JoshJHTX
As title infers, what is the deal; does anyone else have this issue? Whole lotta splooge seeping from below the expansion chamber connection to the head. I’ve replaced the o ring set and copper washer and still leaking
kdxdazz
- Country: thailand
- Been thanked: 35 times
Re: Excessive head cylinder splooge
You mean exhaust port leakage, nothing to do with the head
Can be many causes but most common is the pipe is bent and the flange of the exhaust is not sitting flush against the copper washer
- Has thanked: 83 times
- Been thanked: 20 times
Yes, check to see if the pipe is bent. If it has rubbed against the cylinder, it could widen the gap between the cylinder and pipe.
Check the springs and mounting tabs.
