Kdx220 piston design explained
kdxdazz
Country: thailand
Been thanked: 41 times
Post by kdxdazz »
Been meaning to put together a video on the kdx220 Vs kdx200 stock piston comparison, here it is
Been thanked: 55 times
Re: Kdx220 piston design explained
:supz: Excellent video covering the issues. Glad you finally see it wasn't just BS. I think your planned mods for the stock KDX220 piston are smart and hopefully will rectify most, if not all, of the problems with it. Please keep us posted on how it holds up.
Now, on to some of the things you asked about. The open port on the intake side of the piston, along with the bottom edge below it, control when and how much fuel can enter the crankcase ie: intake port timing. The "chambers" on the side of the piston help carry fuel to the transfer ports in the cylinder itself.
On the rings, yes, the one with the groove will carry more oil but has less surface area so I personally think it's a wash as to which will actually last longer. Of course, the extra oil it carries would be nice on the exhaust bridge, which is probably what Kawasaki was thinking, so I would lean toward maybe it's the slightly better option.
Forged vs cast. Cast works just fine IMO/IME, as long as you don't use it for too long depending on riding type. That's why you hear most people opt to change them at about 100 hours of use. Personally, I've run cast much longer than that without issue but I'm a fairly mellow off road rider and not an MX'er. Cast will never live as long as a forged just due to the metallurgy of the two. As you know, metal fatigues over time and at different rates depending on the material it's made from and how it's run. Cast pistons actually expand faster due to their less dense grain structure, yet expand less, hence why they don't require near as much warm up time, and can run tighter cold piston to cylinder clearances, vs their forged counterparts. The place I see some people get in trouble with forged is not having the proper sidewall clearance when cold to allow for expansion as the piston heats up. That said, forged pistons of today expand much less than the forged pistons from 30+ years ago because of improved metallurgy and closer manufacturing tolerances. Following the aftermarket piston manufacturer's recommendation for sidewall clearance on forged pistons, over what OEM says, is a must!
The only critique I have on your video is to turn your camera sideways, if your camera allows it, next time as it will make for a better view for the details you are trying to show. Otherwise, great vid!
kdxdazz
Country: thailand
Post by kdxdazz »
glad just 1 person likes my vid on a 20 year old mystery lol, i'll experiment with changing the camera to the side but might need a taller tripod, i'll post before and after photos of the deburring process
have the piston and cylinder in front of me now and still can't work out the chambers in the piston,i see they cross the path of the transfer ports but they are never open to the crankcase so how does fuel get into the chambers? do you have any articles or diagrams to show the workings of this?
actually as ive been looking i see the centre of the chambers line up exactly with the bridge between the transfer ports so now i'm more confused
Yeah, trying to actually see how the ports work and transfer fuel/air is tough! I was told that years ago by an old 2T mechanic but, you know, looking at it now I don't see how that would work on the KDX's cylinder. Looks like it's probably more likely there to help lubricate the piston/transfer port edge. I might have to make some inquiries to get to the bottom of this.
kdxdazz
Country: thailand
Post by kdxdazz »
My guess is lubrication too but I good example of how myths begin, we hear something and repeat it only to find out 10 years later it wasn't true
kdxdazz wrote: 01:54 pm Jun 07 2023 My guess is lubrication too but I good example of how myths begin, we hear something and repeat it only to find out 10 years later it wasn't true
So true.
Thank you for the various videos on your channel. I watched several.
This is a very good one. I appreciate you showing the differences.
Has thanked: 309 times
Been thanked: 144 times
Re: KDX220 piston design explained
https://www.cmsnl.com/kawasaki-kdx220-a ... 55385.html
I noticed, after digging up some KDX220SR cylinder head info & wondering if the piston was the same, that I see two part numbers for KDX220 pistons, which are NOT different due to SR / B street model vs R / A offroad model....
13001
PISTON-ENGINE
130011423
supersession: 130010133
oversize info
€ 157.50
(USD $162.22 )
I'm going to bet that the one that has been superseded is likely the original made by SK Pistons of higher quality, and the one that is showing as the "superseded by:" is likely the one that kdxdazz had received when ordering a new OEM, which was made by ART Pistons and is the one notorious for cracking and self destructing....
CMS NL still shows that you can buy the the first part # 13001-1423 being available, as best as I can tell
https://www.cmsnl.com/kawasaki-kdx220-a ... 130011423/
And the one I suspect to be the problematic ART Pistons version # 13001-0133 with photo on CMSNL.com :
https://www.cmsnl.com/products/piston-engine_130010133/
13001-0133:
@kdxdazz - can you confirm via the photo if that's the ART Pistons version which you made the video of?
https://en.impex-jp.com/catalogs/moto/k ... 92974.html shows that the 13001-1423 is no longer available, however.
Has thanked: 43 times
Been thanked: 110 times
kdxdazz: I liked the video and appreciate the effort expended to make & share it. I noticed a few of the features you described when I replaced the stock cast KDX220 piston with the forged Wossner piston. But, I wasn't as thorough as you and didn't see all that you revealed. Thank you very much.
kdxdazz
Country: thailand
Post by kdxdazz »
I can't tell from the photo if it's ART or SP. I see the different part numbers as you said, I think the only way to know is to call whoever is selling and ask them to look inside the piston
If I had to take a guess I'm going to say both pistons are made the same but the difference is in the deburring, the ART had zero deburring, as you know both my kdx220's are using the stock kdx220 ART piston that I deburred myself, no blow ups yet haha 😂
Appreciate the feedback Billie, I always like to look at things from a very detailed perspective, viewing things through a jewellers loop really helps with that and next on my shopping list is a stereoscopic microscope
I did 6 sets of forks rebuilds last year and viewed all the chrome through a jewellers loop, the detail is amazing and seeing how manufacturers surface finish compared to worn chrome
kdxdazz,
You are welcome. You really did a bang up job making and sharing many keen observations.
Excersing attention to detail is a wonderful skill to possess. My engineering design & construction career necessitated attention to detail. If I were to cast a wish at this point (retirement), then I wish I could weld half as well as the professional welders in this forum (you included).
About getting a stereo scope: I know of two universities in California that sell their older lab equipment. It's possible to get all kinds of neat stuff for cheap. Maybe there's something like this for you.
Dunno if you saw this set of posts a few years ago: I used a bore scope to determine whether there was an OEM piston in the used KDX 220 I purchased. Use of the bore scope eliminated cylinder head and cylinder removal.
viewtopic.php?p=213441#p213441
@kdxdazz I believe a member here had previously mentioned they very much wanted a cast piston, but if I recall, it was for a 200 application and I believe it was in a KDX/KX hybrid build. The guy who documented his use of this Namura piston stated that they were made in Japan. They went with a Namura piston, which I had not heard of in regards to being available for our bikes. I believe it is a hypereutectic type piston, based on quickly browsing their piston page on the Namura website.
I just looked up their catalog to find they show a 220 piston, but then after my excitement settled, I realized there was no part number for such a piston in the blanks next to the piston size listing in their catalog... While a quick Google search shows people questioning their quality, it has to be better than the OEM version manufactured by ART Pistons.... I'm wondering if they stopped making them and this person just got an old stock version, or perhaps it was a Chinese fake using this name brand?
Here's the catalog
I'll have to do some more digging, I'm on lunch break now and have to get back to work.
https://www.namura.com/products/pistons/
Their catalog also lists oil seal kits, top end gasket kits, top end bearing of course, and I believe connecting rods as well part number I believe is cut off in that screenshot, it's a few more columns to the right), the part numbers further to the right.
kdxdazz
Country: thailand
Post by kdxdazz »
I interesting, I've heard of namura but never seen anyt of their products in real life, I wonder why no companies make a cast piston for the 220
In Thailand here we have many 69mm pistons available but none with a piston port cutout, I might message a few sellers and see if I can get some measurements
I'm certainly glad I didn't go with a forged piston, I was out road riding yesterday, by the time I got to the top of the mountain the engine temp was 80 Celsius, by the time I free wheeled to the bottom the engine temp was 45 Celsius
Im still using the OEM Art piston in both my bikes although I did spend some time carefully deburring it, still going strong although I have no way of inspecting it without taking off the barrel
Going to try put together a DIY lectron rod grinding video today
