Hello
I have kdx200 e series
It has a sticker that says 32:1 mixture
Now my question is do i have to keep mixing at this measurements keeping in mind that it is 2016 and using the castrol power rs 2t (tts) oil
Is this oil more advanced (better lubrications) than the 2stroke oils in 91
Fuel/oil mixture
- Has thanked: 194 times
- Been thanked: 49 times
Re: Fuel/oil mixture
Where and how do you ride your KDX? Higher rpm requires more oil, in general.
- C George
- Been thanked: 3 times
Fuel/oil mixture
OIls have come a long way in the last 20 years ,,,, oil debates we don't need to get into as it's mostly personal preference
- KDXohio
Klotz r50 at 40:1 is what I run
I would mix the oil at the ratio recommended by the oil manufacturer.
Amsoil 50:1 do me.
Amsoil 50:1 do me.
- Tyl3r
X2 - I run the Amsoil Sabre at 80:1doakley wrote:I would mix the oil at the ratio recommended by the oil manufacturer.
Amsoil 50:1 do me.
ohgood
- Been thanked: 10 times
32:1 is the manufacturers recommendation because they don't want to be on the hook for engine seizures. Any modern oil at any ratio (32:1, 40:1, 50:1) will work fine. The two big things to keep in mind is that you pick an oil and ratio, and then jet to it. If you change anything then you'll need to rejet to get the best performance
