Fuel/oil mixture
Jasper
Country: Belgium
Fuel/oil mixture
Post by Jasper »
Hello
I have kdx200 e series
It has a sticker that says 32:1 mixture
Now my question is do i have to keep mixing at this measurements keeping in mind that it is 2016 and using the castrol power rs 2t (tts) oil
Is this oil more advanced (better lubrications) than the 2stroke oils in 91
Has thanked: 50 times
Been thanked: 17 times
Re: Fuel/oil mixture
Where and how do you ride your KDX? Higher rpm requires more oil, in general.
C George
Fuel/oil mixture
Post by C George »
OIls have come a long way in the last 20 years ,,,, oil debates we don't need to get into as it's mostly personal preference
KDXohio
Post by KDXohio »
Klotz r50 at 40:1 is what I run
I would mix the oil at the ratio recommended by the oil manufacturer.
Amsoil 50:1 do me.
Tyl3r
Post by Tyl3r »
doakley wrote:I would mix the oil at the ratio recommended by the oil manufacturer.
Amsoil 50:1 do me.
X2 - I run the Amsoil Sabre at 80:1
ohgood
Post by ohgood »
You'll be fine with whichever oile , just make sure you aren't lean.
32:1 is the manufacturers recommendation because they don't want to be on the hook for engine seizures. Any modern oil at any ratio (32:1, 40:1, 50:1) will work fine. The two big things to keep in mind is that you pick an oil and ratio, and then jet to it. If you change anything then you'll need to rejet to get the best performance
