Removing compression bolt assembly on USD forks
- KDX220PHIL
I am cleaning out my KX forks and trying familiarize myself with the new to me setup.
What is the trick in removing the compression bolt, do I need the special damper rod holder tool, can I use an impact wrench carefully? The idea of the impact wrench seems a ltitle harsh not for taking off but for putting back together. Has anyone tried cutting notches out of a piece of pipe and using that as a damper rod holder tool?
Any tricks or help is appreciated.
Thanks.
Thanks.
All you really have to do is turn forks right side up (that's USD
) compress them and then use the 14mm allen on the impact wrench and using short bursts until it comes loose, then take it the rest of the way off by hand.
- KDX220PHIL
Yup... unless you have "the tool"
You have the cartridge out???
- KDX220PHIL
- KDX220PHIL
- KDX220PHIL
Yeah I forgot about that, it is pretty much identical to the maual I am reading. I skipped the part where it says to remove the compression bolt assembly and I moved on to the seals. I do not see how removing the compressio bolt assembly before removing the seals makes a difference, If i were just changing seals I don't think I would bother removing the compression bolt, but for cleaning purposes and curiosity I must get in there.
Judging by the pic, it doesnt look like it takes much force to hold the damper rod in place afterall, this skinny mechanic can do it single handed
Thanks Inda.
Thanks Inda.
I hope you don't (at the time written) have the cartridge out. That's what the base valve screws INTO, ain't it?
Well, the push rod and cylinder is what I'm calling the 'cartridge'.
Anyway...my point is this: You don't have to fully reassemble the thing to get the pressure you need on the inside to get the valve out. Pretty much just the spring with its guide, turn in RSU, hit it with 'The Gun!'
Not that any of it matters. Since 12-31, I'm sure you got it all done by now!
- KDX220PHIL
