Newcomer from Belgium
Gargamel88
Post by Gargamel88 »
Hi.
I am Belgian (from Belgium, I speak french)
I apologize for my English is pretty bad (helped a little by google, lol)
I am 26 and I am (as you all) fan of KDX, especially the latest model of KDX 200/220.
I had a KDX 200 1999 ago 4 or 5 years, and I made the mistake of selling it to a friend.
I have recently a KX 250 2002, as follows:
I just change it to supermotard (for road use), and it is the result, lol:
She is too brutal and wicked for me. Then the gearbox (5 only) is not adapted.
I would like to regain the engine flexibility of my old KDX. I LOVE this engine ! With racing exhaust, it's awesome.
But kx parts can be found much more easily, and appearance is prettier.
I therefore intend to Find an KDX 200 or 220 (after 95) and make a hybrid.
KX frame, "and KDX engine" :)
It appears that there are several people here who made this hybrid?
Thanks for reading me.
FilipinoAviator
Post by FilipinoAviator »
Welcome! That sounds like a great combination!
diymirage
Re: Newcomer from Belgium
Post by diymirage »
welcome aboard
I know we recently had at least one other "walonier" join
cant remember his screen name though
Gargamel88
I have read a little this forum looking for information for my project, and I admit that this post scared me:
http://www.kdxrider.net/forums/viewtopi ... kenschwinn
Countless modifications to discourage me ^^ I thought it would be easier ;)
For the modification of the swingarm, I expected it.
The engine mounts, obviously; but modify the exhaust, cylinder head, air box, and others ... I did not expect it: P
I'm in talks to buy back my old KDX to the friend to whom I had sold.
It was she, when I had:
It is not at all in the same condition as when I had :cry:
She is currently "abandoned in its own juice" because it is in ignition failure.
Serious breakdown, I had already looked old. The stator was defective. Replaced, then rode the bike a little bit and then grabs engine misfire and turn off.
The stator smells burnt, and the bike restarts if it is replaced. But when riding a bit, when pulled in, engine misfire, Then turn off ...
Nobody understands what is happening, the electrical circuit looks good, changed ignition coil.
But! I renovated the engine with a cast-iron shirt, new connecting rod bearings, and all it takes.
Perhaps it would remove the top engine to check if piston and reboring needed.
Stay tuned! ;)
There are many ways to do a hybrid, some involve much less modification depending on which parts you use for the build. When I did mine it was engine mounts, swingarm, removing rear head stay and some small bracket fabrication for the pipe. All very simple with just standard tools and use of a welder. The payoff when complete is worth it.
ced64k
Post by ced64k »
diymirage wrote:welcome aboard
It's me :D
Bienvenue Gargamel88 :mrgreen: Tu es de quel coin ?
Has thanked: 50 times
Been thanked: 17 times
Welcome to the forums.
Bonjour and stuff, y'all. :partyman:
Gargamel88
ced64k wrote:Bienvenue Gargamel88 :mrgreen: Tu es de quel coin ?
Je viens d'un village près de Nivelles, et toi ? :wink:
bufftester wrote:There are many ways to do a hybrid, some involve much less modification depending on which parts you use for the build. When I did mine it was engine mounts, swingarm, removing rear head stay and some small bracket fabrication for the pipe. All very simple with just standard tools and use of a welder. The payoff when complete is worth it.
Thank you :)
What have you use as frame? I read kx 2001 and 220kdx engine. But ... KX 125 or 250 ?
The frame and the engine mounts are the same on the 125 and 250 ?
The KDX 200 engine (1999) and KDX 220 has the same shapes and engine mounts I believe?
Besides the KDX 200 has to happen,i have already :
- KX 250 2002 (or 2001?) supermotard, which broke my arm...
- KX 250 1998 completely dismantled for rebuild but complete
- KX 250 1994 -1998 parts (frame, and others): I wanted to base myself on that frame to create the hybrid.
From what I compared, the motor and lower part of the frame is the same from 1998 to 2002. Except for the aluminum rear frame of 2002 and supports fairings and tank. I'm right ?
Tedh98
Post by Tedh98 »
Gargamel88 wrote: The frame and the engine mounts are the same on the 125 and 250 ?
The engine cradle on a 250 is larger to accept the larger engine. You can use a 250 frame for the KDX engine, but it will look a little off - like you've put a small motor in there. It will also create some more work on getting a pipe to fit. You'll need to make an extension on the pipe so that it will clear the downtube. Hope that makes sense.
The 200 and 220 both use the same bottom end, so all dimensions are the same.
ced64k
Post by ced64k »
Gargamel88 wrote:Je viens d'un village près de Nivelles, et toi ? :wink:
Chièvres
+1 what Ted said. You can use a KX250 frame, but the KDX200/220 grew out of the KX125 and the H/220 motors fit the 99-02 KX125 frames with almost no modification.
Gargamel88
Thanks for these informations :wink:
Because the heavy work that request with the frame 250 kx, I will wait to find a frame KX 125. In any case, I must first resolve the ignition failure on the KDX.
I'll probably rebuild and ride with while waiting for.
Speaking of it, this is it, after years my old KDX is "back" in my house. Photos soon.
I need a CDI to try. :?
I have seen that "osobad" had one for sale, in the section sales.
I'll try to contact him, unless someone in europe (or Belgium ???) would have one ?
Gargamel88
Osobad will not ship out of US :cry:
If anyone has one ... ?
I found this:
http://www.ebay.com/itm/CDI-MODULE-Fits ... 07&vxp=mtr
But ... what will be the quality ?
Given other items it sells, everything seems to come from China.
At home or even in Europe, the model is rare and we find nothing.
Jaguar
Country: Ecuador
Post by Jaguar »
Why go to all the trouble of a hybrid? The short powerband of the KX can be made into a long one with the right exhaust pipe design. Along with making the powerband longer, the power is also spread out and doesn't peak high as before.
Gargamel88
What you say interests me. Have you a concrete example, or someone who would have done?
Modify a 2 stroke exhaust was not done randomly. The length, diameter, angle ... is important and must match with the engine.
However, on the kx 250, there is not only the exhaust which is problematic.
The 5-speed transmission is very short, and it lacks a 6th gear! On supermotard i am very bothered by this.
Jaguar
Country: Ecuador
Post by Jaguar »
5 speed is plenty. I ride a Suzuki 100 on the street and it only has 4 gears. I designed a pipe for it that has a 3000 RPM powerband. I am the creator of a free pipe design program that works on Excel. Read my info on expansion chambers at http://www.dragonfly75.com/motorbike/ECtheory.html
Your KX needs a 6th gear only because the pipe powerband is narrow, which is common for a motocross bike.
Jaguar
Country: Ecuador
Post by Jaguar »
the main limiting factor if you want a broad powerband pipe on your KX is if there is room for it.
