1998 kx hybrid project
Postigo
Post by Postigo »
Bought a 1998 kx 125 rolling chassis today for a cheap and I want to do the conversion with a 220 engine that I have as a spare. Can I modify the 1998 swing arm or is better to go with a 1999 and up swing arm?
diymirage
Re: 1998 kx hybrid project
Post by diymirage »
cant answer your question but its good to see your still fiddling with the bikes
if it comes out looking like your other bikes it will be a nice ride for sure
will you be stockpiling tanks for the KX as well ? :lol:
Tedh98
Been thanked: 2 times
Post by Tedh98 »
Same here - I dont know enough about the specifics of those years of bikes.
I would think the easiest and most predictable path would be to use the swingarm that came with the bike.
A few months ago someone tried using the KDX swingarm on the hybrid and then ran into some problems. You may be going down a similar path if you try to use the '99 swingarm (assuming it isnt a direct swap).
Postigo
Post by Postigo »
Thanks for the comments guys. I will be taking photos of the project to share. :grin:
Postigo
Post by Postigo »
6 Riders
Post by 6 Riders »
Double
6 Riders
Post by 6 Riders »
Postigo wrote:Some update on the hybrid project after about four hours:
A friend with a milling machine resize the engine cases to 17mm
https://www.dropbox.com/s/p2c6t9ky1ioez ... .13.37.jpg
Then I start with the swing arm modification. there is no need to weld the 94-98 swing arm just be careful wile cutting the left side.
https://www.dropbox.com/s/yjm6ejt0ae7qj ... .23.20.jpg
https://www.dropbox.com/s/qshmhbxp3igad ... .23.28.jpg
https://www.dropbox.com/s/tid7ikevi7aml ... .23.33.jpg
As in any hybrid project I have some minor issues with the air box and pipe fitting but everything is going smooth.
https://www.dropbox.com/s/ym5hrvzha2m1s ... .45.32.jpg
https://www.dropbox.com/s/xvagfwg27kbkr ... .17.07.jpg
https://www.dropbox.com/s/h42tbisgx0yod ... .18.09.jpg
https://www.dropbox.com/s/joo6qejqgvwzx ... .17.29.jpg
Postigo
Post by Postigo »
6 Riders
Post by 6 Riders »
Postigo wrote:?????
Sorry I was fixing the links.
6 Riders
Post by 6 Riders »
A question about this...(NOT BASHING)...Since the 95+ KDX frame is similar to the older KX frames, what is the point in the hybrid? I get it if you are using a much newer bike, an aluminum frame or hybridding an E series, but the 95 and up KDX has a pretty similar frame doesn't it?
Postigo
Post by Postigo »
Thanks for the fix, I'm doing this because already have a complete spare engine plus wiring and I found a complete rolling chassis for $150. I think is a good idea to keep my 220 as is and build a new bike with better suspension and ergos for less than $1000.
Postigo
Post by Postigo »
Did I mention the challenge and the fun factor? :mrgreen:
