1998 kx hybrid project
- Postigo
Bought a 1998 kx 125 rolling chassis today for a cheap and I want to do the conversion with a 220 engine that I have as a spare. Can I modify the 1998 swing arm or is better to go with a 1999 and up swing arm?
- diymirage
Re: 1998 kx hybrid project
cant answer your question but its good to see your still fiddling with the bikes
if it comes out looking like your other bikes it will be a nice ride for sure
will you be stockpiling tanks for the KX as well ?
-1997 KDX 220 project bike
- Tedh98
- Been thanked: 2 times
Same here - I dont know enough about the specifics of those years of bikes.
I would think the easiest and most predictable path would be to use the swingarm that came with the bike.
A few months ago someone tried using the KDX swingarm on the hybrid and then ran into some problems. You may be going down a similar path if you try to use the '99 swingarm (assuming it isnt a direct swap).
- Postigo
Thanks for the comments guys. I will be taking photos of the project to share.
- Postigo
Some update on the hybrid project after about four hours:
A friend with a milling machine resize the engine cases to 17mm
[https://www.dropbox.com/s/p2c6t9ky1ioe ... 23.20.jpg]
https://www.dropbox.com/s/qshmhbxp3igad ... .23.28.jpg
https://www.dropbox.com/s/tid7ikevi7aml ... .23.33.jpg
As in any hybrid project I have some minor issues with the air box and pipe fitting but everything is going smooth.
https://www.dropbox.com/s/ym5hrvzha2m1s ... .45.32.jpg
https://www.dropbox.com/s/xvagfwg27kbkr ... .17.07.jpg
https://www.dropbox.com/s/h42tbisgx0yod ... .jpg[url] https://www.dropbox.com/s/joo6qejqgvwzx ... .17.29.jpg[/url]
- 6 Riders
Double
- 6 Riders
Postigo wrote:Some update on the hybrid project after about four hours:
https://www.dropbox.com/s/p2c6t9ky1ioez ... .13.37.jpg
Then I start with the swing arm modification. there is no need to weld the 94-98 swing arm just be careful wile cutting the left side.
https://www.dropbox.com/s/yjm6ejt0ae7qj ... .23.20.jpg
https://www.dropbox.com/s/h42tbisgx0yod ... .18.09.jpg
- Postigo
- 6 Riders
Sorry I was fixing the links.Postigo wrote:?????
- 6 Riders
A question about this...(NOT BASHING)...Since the 95+ KDX frame is similar to the older KX frames, what is the point in the hybrid? I get it if you are using a much newer bike, an aluminum frame or hybridding an E series, but the 95 and up KDX has a pretty similar frame doesn't it?
- Postigo
Thanks for the fix, I'm doing this because already have a complete spare engine plus wiring and I found a complete rolling chassis for $150. I think is a good idea to keep my 220 as is and build a new bike with better suspension and ergos for less than $1000.
- Postigo
Did I mention the challenge and the fun factor?
