Hid's
Brom32
Hid's
Post by Brom32 »
How hard would it be to run hid's in a 04 Kdx200? What about leds?
04 Kdx200 w/ PC Platinum 2
Has thanked: 10 times
Been thanked: 12 times
Hid's
With a stock stator it would be impossible. You would need to rewind the stator, add a rectifier to convert to DC, add a battery, and then you would be ok to run one 35 watt HID. Now, LED's are a much better option. Less draw, and regardless of what you have been told, they will run on AC.
Brom32
Re: Hid's
Post by Brom32 »
How well do the led's work vs the stock headlight
Sent from my XT907 using Tapatalk
Hid's
Why run LED? Why not just run a higher wattage halogen?
Brom32
Re: Hid's
Post by Brom32 »
Better overall lighting
koshari
Re: Hid's
Post by koshari »
Slick_Nick wrote:Why run LED? Why not just run a higher wattage halogen?
Stator limitations.
I got a 6 cree led that fits in the front plate reflector cutout. Havnt had time to fit it yet.
ecojbr
Hid's
Post by ecojbr »
LED, tons of light per wattage. I am running two 6 watt on a factory kx 250 stator. A kdx could run two 15's and that would be killer light. Just make sure you get the proper color LED.
04 kx220 hybrid
03 kx 250
05 kdx 200
Brom32
Re: Hid's
Post by Brom32 »
ecojbr wrote:LED, tons of light per wattage. I am running two 6 watt on a factory kx 250 stator. A kdx could run two 15's and that would be killer light. Just make sure you get the proper color LED.
I was thinking a purple or pink
Haha jk
