1985 200 piston kit
froggy
1985 200 piston kit
I am trying to find a piston kit for my 85 kdx 200 with no luck. Will a piston from a 86-88 200 work? Any help would be greatly appreciated. I love my 85 but it needs the cylinder redone with a new piston kit to keep her running for years to come.
froggy
1985 200 piston kit
No replys, so I will post what I found out. A 86-2006 uses the same piston, so I ordered one for my 1985. Their is a difference. I ordered a weisco and the skirt is a little too long. I filed down the skirt a couple of mm's and now it works fine. I raced a vintage race race last weekend with no issues. This may be helpfull to others as their is not any kits available for the 83-85 200's. A newer piston has a bigger hole in the back of the piston over a stock one, but other than that the pistons are the same, with the exception of the longer skirt. Their was a little lip on the weisco piston skirt, that is what I filed down with a bench sander, took 5 minutes, very simple.
Hope this may help somebody in the future.
- Has thanked: 83 times
- Been thanked: 20 times
Re: 1985 200 piston kit
Thank you for sharing your findings.
freight
gonna give this a shot as partzilla cancelled my order. thanks again for sharing. freight
De250r
Thanks for the tip. I've been wondering that very question
Sent from the back woods of vt via patchy Internet
Live free and ride hard
GS
De250r
I pulled my 84 apart and it was over bored and sleeved and needed another bore so I orderd an 68mm Wiseco for a newer kdx. I got the piston and its exactly the same height. Doesn't seem to be a lip to grind off.
