Front Socket Oil Seal Removal
bender
Post by bender »
Hey Guys,
Finally got my KDX 250 92" cleaned up and started although I now have a front sprocket oil seal leak. I have a new seal ready to go in only problem I cant take the old one out? I tried prying it out with an hex key but it wont budge, it's moved out a little but not much.
Does anyone have any suggestions / proven processes?
Cheers
bender
Post by bender »
Never mind got it out with a flat head screw driver by holding it on an angle, came out second tap. Do I need to grease or oil the new seal though? Saw on-line some guys just use engine oil on the new one then tap it in, is this ok?
Has thanked: 9 times
Been thanked: 17 times
Re: Front Socket Oil Seal Removal
Yeah, any kind of lubrication along the lip of the seal, and tap tap tap'a'roo.
Roadhazardguy
Post by Roadhazardguy »
[youtube][/youtube]
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
I know you already have the seal changed but I have one of these that works great for changing seals with any kind of shaft in the hole.
http://www.mactools.com/ShopOnline/Prod ... fault.aspx
bender
Post by bender »
Seal is in (TAP TAP TAP). I figured out I needed two O rings as well. There were none when I took the old seal out, it was as though they has disintegrated.
