Hey Guys,
Finally got my KDX 250 92" cleaned up and started although I now have a front sprocket oil seal leak. I have a new seal ready to go in only problem I cant take the old one out? I tried prying it out with an hex key but it wont budge, it's moved out a little but not much.
Does anyone have any suggestions / proven processes?
Cheers
Mike
Front Socket Oil Seal Removal
bender
Never mind got it out with a flat head screw driver by holding it on an angle, came out second tap. Do I need to grease or oil the new seal though? Saw on-line some guys just use engine oil on the new one then tap it in, is this ok?
- Has thanked: 15 times
- Been thanked: 28 times
Re: Front Socket Oil Seal Removal
Yeah, any kind of lubrication along the lip of the seal, and tap tap tap'a'roo.
Roadhazardguy
[youtube][/youtube]
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
- rbates9
- Been thanked: 2 times
I know you already have the seal changed but I have one of these that works great for changing seals with any kind of shaft in the hole.
http://www.mactools.com/ShopOnline/Prod ... fault.aspx
bender
Seal is in (TAP TAP TAP). I figured out I needed two O rings as well. There were none when I took the old seal out, it was as though they has disintegrated.
