Top end rebuild
Trails Boy
Top end rebuild
So i went to have my cylinder measured and it came out at 66.03mm and was told i need a 65.98mm piston... Problem is I've only been successful in finding one that size on ebay (new) made by pro-x specified for a crf-150 would that work? If not Wiesco makes a 66mm piston... Would that work?
- Has thanked: 15 times
- Been thanked: 28 times
Top end rebuild
Is this the 87? If so, that is within factory spec. You can put a std wiseco in it and be fine, or a pro-x b/c/d.
Trails Boy
Top end rebuild
If it's a STD piston, it will work.Trails Boy wrote:Yes its the 87. So your saying the pro-x that i sa on ebay will work?
Trails Boy
Trails Boy
Trails Boy
david
- Country: UNITED STATES
Top end rebuild
Instead of searching for that size piston, search for one for your spacific bike.
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
gopack4749
Re: Top end rebuild
Exactly. You just need a standard KDX200 piston. Same part from 86 and up I believe.david wrote:Instead of searching for that size piston, search for one for your spacific bike.
Trails Boy
Trails Boy
Re: Top end rebuild
66mm is just the stock bore. The piston will actually mic out a bit smaller than that. Wiseco does not do incremental sizes, pro-x does. I think you're over-thinking. If you want forged, standard size is your only option. For a cast, you could go with a standard C or D pro-x which is very slightly over size. Not enough to make a difference imo.Trails Boy wrote:The 66mm would be the best since its the biggest right?
Trails Boy
