Top end rebuild
Trails Boy
Top end rebuild
Post by Trails Boy »
So i went to have my cylinder measured and it came out at 66.03mm and was told i need a 65.98mm piston... Problem is I've only been successful in finding one that size on ebay (new) made by pro-x specified for a crf-150 would that work? If not Wiesco makes a 66mm piston... Would that work?
Has thanked: 15 times
Been thanked: 28 times
Top end rebuild
Is this the 87? If so, that is within factory spec. You can put a std wiseco in it and be fine, or a pro-x b/c/d.
rbates9
Been thanked: 2 times
Top end rebuild
Post by rbates9 »
A four stroke piston won't work in a two stroke.
Trails Boy
Top end rebuild
Yes its the 87. So your saying the pro-x that i sa on ebay will work?
Top end rebuild
Trails Boy wrote:Yes its the 87. So your saying the pro-x that i sa on ebay will work?
If it's a STD piston, it will work.
Trails Boy
Top end rebuild
How do I know if its a STD piston?
Re: Top end rebuild
The listing should say if its standard or oversized.
Trails Boy
Top end rebuild
It does not say Guess I will need to keep looking :sad:
Re: Top end rebuild
Link?
Trails Boy
Top end rebuild
david
Country: UNITED STATES
Top end rebuild
Post by david »
Instead of searching for that size piston, search for one for your spacific bike.
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
Re: Top end rebuild
david wrote:Instead of searching for that size piston, search for one for your spacific bike.
Exactly. You just need a standard KDX200 piston. Same part from 86 and up I believe.
Trails Boy
Top end rebuild
Okay! That helps so much! Thanks! :supz:
Trails Boy
Top end rebuild
The 66mm would be the best since its the biggest right?
Re: Top end rebuild
Trails Boy wrote:The 66mm would be the best since its the biggest right?
66mm is just the stock bore. The piston will actually mic out a bit smaller than that. Wiseco does not do incremental sizes, pro-x does. I think you're over-thinking. If you want forged, standard size is your only option. For a cast, you could go with a standard C or D pro-x which is very slightly over size. Not enough to make a difference imo.
Trails Boy
Top end rebuild
Okay.. I just went with the Wiesco 66mm.
Thanks for all the help!
