Can anyone reccomend a good chain lube?
Fatherof2
Post by Fatherof2 »
I have been using this stuff, and I hate it! It turns mud into a sticky mess that requires LOTS of elbow grease to get off!
Thank you,
David
tirebiter
Post by tirebiter »
Try Maxima chain guard. Great stuff & easy to clean after..
Been thanked: 17 times
Has thanked: 30 times
Been thanked: 46 times
This is what I use! :lol:
diymirage
Post by diymirage »
i wonder (and i appologize if this is a stupid idea) how chainsaw chain lube would hold up ?
it seems a chainsaw chain gets put through even more abuse then a KDX chain so if the lube works in that situation it should also work on the trails right ?
:oops:
forget it
zomby woof
Post by zomby woof »
I think if you have an O ring chain, you don't really need to lube it. I spray a little penetrating oil on mine to keep it from rusting after washing.
Ontario, Canada
Fatherof2
Post by Fatherof2 »
Thanks guys!
D.
For God and Country......Geronimo, Geronimo, Geronimo!!
gsa102
Post by gsa102 »
I use the Maxima lube on both O-ring and non O-ring chains. I think sticky is a good thing for lubrication.
96 KDX 200, 09 YZ 250
fuzzy
Post by fuzzy »
Rem-oil rocks!
Chain bar oil is basically plain-jane motor oil.
dan46n2
Post by dan46n2 »
Dupont Teflon lube from Lowes. Not nearly as much mess as others. Been using it on my streetbike for a few years now.
turtle
Post by turtle »
+1 on Maxima here.
Bill
Central IL
2004 KDX220R
2011 Triumph Tiger 1050 SE
KarlP
Post by KarlP »
For me, on an o-ring chain, no lube is the best lube.
the lube can't get anywhere it will do any good, anyway.
cornishwrecker220
Post by cornishwrecker220 »
PJ1 blue lable....does exactly what it says on the tin....wont fly off.
dan46n2
Post by dan46n2 »
DID recommends lubing your chain, as the grease is only in certain areas of the chain.
http://www.didchain.com/chainMaintenance.html
YMMV.
zomby woof
To guard against corrosion on O ring chains, which is the idea behind the penetrating oil.
Ontario, Canada
gregp
Post by gregp »
I run an o-ring chain (doesn't everybody?) and just spray it down with WD-40 after every ride, and wipe it off with a rag. It stays nice and clean (I have one of those fancy looking Gold ones). I have been using this method for years, and I have never noticed any accelerated wear, or any other issues. A chain/sprocket set usually lasts me at least a full year of casual trail riding use.
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
nearma12
Post by nearma12 »
I've been using "Lucas Oil" Chain Lube. It is foamy when it comes out, then turns to liquid in a few seconds. That makes it easy to spray it where you want it. It also penetrates very well.
I hear lots of people say that they don't lube an O-ring chain. Just my opinion.....but, I think that the rollers still need a film of lube between them and the sprockets to reduce friction. At the very least. Right? :?
1991 KDX250
2000 KX250
zomby woof
No.
Nothing will stay there any longer then a few seconds.
Ontario, Canada
Its never a bad idea to lube an O ring chain.
