Fatherof2
Posts: 224 Joined: 08:43 am Dec 14 2010
Post
by Fatherof2 » 04:04 pm Oct 03 2011
I have been using this stuff, and I hate it! It turns mud into a sticky mess that requires LOTS of elbow grease to get off!
Thank you,
David
tirebiter
Posts: 108 Joined: 10:39 pm Aug 18 2011
Post
by tirebiter » 04:23 pm Oct 03 2011
Try Maxima chain guard. Great stuff & easy to clean after..
Posts: 1708 Joined: 10:06 pm Oct 22 2009
Has thanked: 4 times
Been thanked: 19 times
Post
by Slick_Nick » 06:04 pm Oct 03 2011
Posts: 6262 Joined: 05:11 am Aug 23 2009
Has thanked: 34 times
Been thanked: 57 times
Post
by ss109 » 07:09 pm Oct 03 2011
This is what I use!
diymirage
Posts: 2907 Joined: 05:00 pm Sep 19 2011
Post
by diymirage » 07:31 pm Oct 03 2011
i wonder (and i appologize if this is a stupid idea) how chainsaw chain lube would hold up ?
it seems a chainsaw chain gets put through even more abuse then a KDX chain so if the lube works in that situation it should also work on the trails right ?
newbbewb wrote: DIYmirage has it right.
1996 KDX 200
plated street toy (
barney edition )
-1997 KDX 220 project bike
scheckaet
Posts: 3740 Joined: 12:09 am Nov 10 2005
Been thanked: 1 time
Post
by scheckaet » 07:33 pm Oct 03 2011
forget it
zomby woof
Posts: 295 Joined: 11:42 am Oct 22 2009
Post
by zomby woof » 07:33 pm Oct 03 2011
I think if you have an O ring chain, you don't really need to lube it. I spray a little penetrating oil on mine to keep it from rusting after washing.
Ontario, Canada
Fatherof2
Post
by Fatherof2 » 07:22 am Oct 04 2011
Thanks guys!
D.
gsa102
Posts: 453 Joined: 12:33 pm Aug 16 2011
Post
by gsa102 » 07:40 am Oct 04 2011
I use the Maxima lube on both O-ring and non O-ring chains. I think sticky is a good thing for lubrication.
96 KDX 200, 09 YZ 250
fuzzy
Posts: 3437 Joined: 01:29 pm Jun 18 2003
Post
by fuzzy » 08:05 am Oct 04 2011
Rem-oil rocks!
Chain bar oil is basically plain-jane motor oil.
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
dan46n2
Posts: 89 Joined: 10:27 am Jun 23 2011
Post
by dan46n2 » 08:34 am Oct 04 2011
Dupont Teflon lube from Lowes. Not nearly as much mess as others. Been using it on my streetbike for a few years now.
turtle
Posts: 460 Joined: 02:00 pm Jun 21 2010
Post
by turtle » 08:53 am Oct 04 2011
+1 on Maxima here.
Bill
Central IL
2004 KDX220R
2011 Triumph Tiger 1050 SE
KarlP
Posts: 1484 Joined: 02:26 pm Jun 29 2005
Post
by KarlP » 12:59 pm Oct 04 2011
For me, on an o-ring chain, no lube is the best lube.
the lube can't get anywhere it will do any good, anyway.
'08 KTM200xc
KX100 for the boy
cornishwrecker220
Posts: 743 Joined: 06:37 am Nov 22 2009
Post
by cornishwrecker220 » 01:38 pm Oct 04 2011
PJ1 blue lable....does exactly what it says on the tin....wont fly off.
zomby woof
Post
by zomby woof » 07:00 pm Oct 04 2011
To guard against corrosion on O ring chains, which is the idea behind the penetrating oil.
Ontario, Canada
gregp
Posts: 498 Joined: 03:44 pm Jul 30 2009
Post
by gregp » 07:48 pm Oct 04 2011
I run an o-ring chain (doesn't everybody?) and just spray it down with WD-40 after every ride, and wipe it off with a rag. It stays nice and clean (I have one of those fancy looking Gold ones). I have been using this method for years, and I have never noticed any accelerated wear, or any other issues. A chain/sprocket set usually lasts me at least a full year of casual trail riding use.
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
nearma12
Posts: 87 Joined: 10:20 pm Feb 20 2009
Post
by nearma12 » 09:05 pm Oct 04 2011
I've been using "Lucas Oil" Chain Lube. It is foamy when it comes out, then turns to liquid in a few seconds. That makes it easy to spray it where you want it. It also penetrates very well.
I hear lots of people say that they don't lube an O-ring chain. Just my opinion.....but, I think that the rollers still need a film of lube between them and the sprockets to reduce friction. At the very least. Right?
1991 KDX250
2000 KX250
zomby woof
Post
by zomby woof » 10:19 pm Oct 04 2011
No.
Nothing will stay there any longer then a few seconds.
Ontario, Canada
Post
by Slick_Nick » 10:19 pm Oct 04 2011
Its never a bad idea to lube an O ring chain.
