Anyone know a site that will weld then rethread stud holes?
Johnkdx200
As the title suggest I need a place that will redo a few studs on my cylinder.
kawie
Johnkdx200
Helicoils seem to be working so far. It was idling really high so I was using the kill switch to stall it then let it rev up until it warmed up. It still idles a little high when it's warmed up but I was able to ride it around the yard a little bit. Adjusting the idle speed screw didn't appear to do anything but i'm also using the old head gasket as the new one isn't here yet and I didn't want to put the new one on if the helicoils weren't going to hold. A few drops of water were coming out of the gasket so I know it's not sealing properly. Also waiting on the exhuast gasket since it only has the orings and isn't sealing proper.
