Anyone know a site that will weld then rethread stud holes?
Johnkdx200
Post by Johnkdx200 »
As the title suggest I need a place that will redo a few studs on my cylinder.
GCE61
Post by GCE61 »
would HeliCoils be an option?
rbates9
Post by rbates9 »
GCE61 wrote:would HeliCoils be an option?
There is also "inserts" that hold much better than HeliCoils but take up more space.
kdub405
Post by kdub405 »
+1
Ride on
kawie
Post by kawie »
http://www.timesert.com/
these would be a better way to go than the helicoils.
Kawie
2004 kx125
2001 kdx220
2000 kx250
1996 kx250
Johnkdx200
Helicoils seem to be working so far. It was idling really high so I was using the kill switch to stall it then let it rev up until it warmed up. It still idles a little high when it's warmed up but I was able to ride it around the yard a little bit. Adjusting the idle speed screw didn't appear to do anything but i'm also using the old head gasket as the new one isn't here yet and I didn't want to put the new one on if the helicoils weren't going to hold. A few drops of water were coming out of the gasket so I know it's not sealing properly. Also waiting on the exhuast gasket since it only has the orings and isn't sealing proper.
JoKDX220r
Post by JoKDX220r »
try using the ultra-black silicon at the exhaust it helps a lot !
