Are jetting changes needed after head mod?
Questions and Answers about the best carb and Head mods available for the KDX.
Grayhorse
Post by Grayhorse »
I just got my modded head back from RB, before I sent it I thought my jetting was right on(RB carb). Will jetting changes be needed with the new head?
96 KDX 200 H2
IdahoCharley
Post by IdahoCharley »
It should still be close.
A tighter squish (resulting in a better combustion) should allow you to lean it out a little from your previous jetting for a given temperature and alitude. Bottom Line - your engine should be a little richer (jetting wise) than it was prior to sending it to RBD. :wink:
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
RBD
Been thanked: 6 times
Post by RBD »
Very well said IdahoCharley, spot on.
Ron
IdahoCharley
RBD wrote:Very well said IdahoCharley, spot on.
Ron
Thanks Ron.
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
river
Post by river »
IdahoCharley wrote:It should still be close.
Sorry for the rookie question. What is squish? And I presume you are saying one needs to install larger jets? What size (or is this obvious to experienced people?)?
Thanks very much.
Has thanked: 26 times
Been thanked: 28 times
>|QBB|QBB<[/url]
Thanks very much.[/quote]
No, you would actually go to a smaller jet to get a leaner mixture.
As for squish, I hope this helps.
river
Post by river »
Thanks for the great pic.
I'm confused then; IdahoCharlie says it needs to run richer, but that the extra squish let's you lean it out. Does this mean if you put rb head/carb on a stock bike it will be too rich, and the squish let's you lean it, but leaving it still richer than stock?
Thx.
Thought I already posted this.......
fuzzy
Post by fuzzy »
No, what IC was it will run richer with the tighter squish....therefore requiring you to lean it out. If you had stock jetting you were most likely in need of a re-jet anyway. Read up on here on how to jet your stuff. Once you know how, it's an indespensable tool.
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
