Aftermarket wheels / hubs to compliment fork upgrades, etc
Has thanked: 309 times
Been thanked: 144 times
I've been digging up some info on KX aftermarket hubs & wheel sets out of curiosity of building another set or two of KDX wheels, so I figured I'd document it here so others can make use of it.
The bottom line here is that there are zero aftermarket front hubs that cater to the KDX/KLX 15mm axle / fork setup or speedometer/odometer drive, so this really only pertains to those upgrading to a minimum of 43mm 1991+ or 1993+ KX forks or other Showa or KYB Japanese fork upgrades which use a larger 17mm, 20mm, or 22mm modern front axle.
After learning of the weight savings of 0.50lbs to 4.8lbs from swapping out the 1988 technology '95-'06 KDX forks to KLX forks (which still use the thin & flexy 15mm KDX axle vs modern 20mm or '91-'92/'93 KX 17mm), or a much greater upgrade to '91-95 KX 43mm inverted forks, RMX250 forks (EXCELLENT KDX SWAP, CORRECT HEIGHT!), DRZ400E/400 or 2002+ DRZ400S forks, or any 1996+ MX/modern enduro forks, as well as eliminating the extreme fork tube underhang, I decided that to match the fork swap wheel up front, why not build up a '97-'02 KX OEM (3 bearing rear hubs) or aftermarket rear with 18" rim and spokes?
I've built up a '97-'98 KX125/250 3-bearing rear hub already that a member here sold me, and was looking for another to do as well. I've got a Kawazuki '04-'06 KX250F / '04-'07 RM-Z250 front wheel here with an OEM Excel Takasago, and a new Excel Takasago FES410 to lace up in place of a cracked D.I.D. U-rim from '99-'02 KX's, same front hub as the 1st gen 4-stroke Kawasaki KX250F & the identical joint venture bike the 1st gen Suzuki RM-Z250.
The OEM double butted plated front spokes and alloy nipples are quite nice & in excellent condition, so I was plenty good with that over aftermarket straight gauge heavy stainless spokes, but for an 18" rear conversion for woods/KDX use, aftermarket Excel stainless spokes + alloy splined nipples or others were mandatory since all MX bikes since '89-ish came with a short sidewall 19" rear.
I'm still shopping for another '97-'98 KX rear hub ('97-'04 KX500 fitment also), but got curious about aftermarket wheels suited for KX125/250/500 models, and figured I'd document my late 2024 findings....
The big thing is that in 2003, most Japanese bike rear axles jumped up to 25mm on nearly all full size MX & serious enduro bikes, which makes adapter spacers necessary. Also, the KX rear rotor pattern went from 6 bolts with a 100mm center bore with 220mm outside diameter rotor size, to 2003+ using 4 bolts and 115mm inside rotor bore @ 240mm outside diameter.
The sprockets I believe remained the same 6-bolt pattern however. The front hubs I believe I'd read still carried the same 4-bolt rotor pattern, please confirm this though.
Most of the available KX500 / '90-'02 KX125/250 aftermarket wheelsets adapt to the 2003+ hubs with a special 220mm rear rotor and *maybe*(?) a special 250mm front rotor (if those 2006+ bikes run a larger front rotor - the front rotor bolt pattern may be the same though????).
They'll have special spacers to step down to the 20mm axle, and in the correct widths for the year of KX requested.
The front hubs won't be adapted for the rather small 15mm KDX/KLX axle, but can come set up for whatever year 1990+ KX etc fork swap which you've chosen.
KDXGarage confirmed 1993 KX125/250 & the typical 1-yr delayed 1994 upgrade to the KX500 is when the front axle jumped up to a 20mm from 17mm, so that's a good minimum period to aim for, '93- '94-'95 KX125/250 forks which mount right KDX250/KLX650R triples to make a bolt-on KDX200/220/250 upgrade.
Warp9 and KKE have adapted 2003+ offerings to fit the '90-'02 KX, which is what we require for the rear, and depending on fork swap choice, for the front also. They have a location in Chino, California as well as Brisbane, Australia.
https://www.kkeracing.com/products/kke- ... 2002-discs
https://www.ebay.com/sch/i.html?_from=R ... =0&_sop=15
https://www.warp9racing.com/product/mx-wheels/
https://aomc.mx/90-31812.html
I emailed KKE about their special conversion rotor to fit the KDX & 2002 & earlier KX 220mm size on the 2003+ rear hubs, and they got back to me with a custom product page that I believe they just made up for my request:
https://www.kkeracing.com/products/kke- ... -1993-2002
$39.99 for the 4-bolt 2003+ hub rear rotor in the 2002 & earlier 220mm diameter vs the later rotors which are all 240mm
For hubs which I believe are made to fit the 1990 or 1993-2002 6-bolt 220mm rear rotors, check these out:
https://www.metricsengineering.co.uk/envy-wheel-hubs/
https://www.instagram.com/envymx_uk/
The actual CNC company who manufactures Talon hubs does sell their own versions called Envy Hubs, but finding them is difficult.
Talon do appear to be perhaps the only ones who offer an aftermarket billet hub that works with the 1990-2002 6-bolt 100mm i.d. / 220mm o.d rear rotors directly.... and probably Envy as well so I have been told.
The '90-'02 hub pictured shows a green hub with 6-bolt rotor flange at least, but I know online sites often use generic generalized photos, but no mention of a special conversion rotor is made, so I think this is a legit assumption... They have a very nice custom ordering request form for front and rear wheels separately, to take into account all variables, colors, sizes, axles and spacer sizes, titanium or steel rotor bolts, sprocket tooth count, etc....
Talon rear hub
https://talon-eng.co.uk/product/tw607a- ... 5-250-500/
Pick your Talon front hub based on your fork swap. I'm using '99-'06 ('04-'07 on the Kawazuki RMZ250, '04-'06 on the identical Kawazuki KX250F joint venture years) front hubs for '98 RM250 forks, FYI, they seemed to work out well although I'll have a custom spacer on one side.
Talon front hubs:
https://talon-eng.co.uk/product-categor ... -kawasaki/
Tusk hubs are available for 2003+ for $139-ish, but will require the special Warp9 or KKE rear 220mm 4-bolt conversion rotors, & custom spacers for those of you who have a metal lathe at your disposal...
MXChamp are a high end Chinese brand that have nice billet purple and green anodized hubs, and upon request, they have special spacers to adapt to the older 20mm rear axles, and also advertise using high quality Japanese bearings, but these will still require the conversion rear rotors mentioned. My friend Sebastien has laced up this brand of hubs before, for a Boyko Racing customer, and vouched that they indeed seem to be of high quality.
As a workaround, there are some pretty nice 2003+ KX and KX250F rear rotor guards that double as caliper hangers, and these could potentially be modified and used with a basic but custom 25mm to 20mm bushing to fit the KDX axle while raising the caliper 10mm further radius to run a 2003+ 240mm KX/KXF rotor in place of the KDX's 220mm rotor...IF the swingarm interface would also be compatible or able to be modified within reason (I wish I'd saved the links for those trick rear rotor guards for KX250F's, I'll dig it up when I get a chance.)
The Tusk and MX Champ hubs will use OEM style spokes, which is nice, but not the period correct off-the-shelf rotors. The Talon, Warp 9, KKE, etc will mostly use their exclusive spokes I believe - double check this. Talon in particular I've read that the hub flanges are taller to run a shorter length spoke for more wheel rigidity.
MX Champ:
https://mxchampusashop.com/products/mxc ... 9075200156
https://www.ebay.com/itm/284257611051
Also, 2003+ KX rears use 9 spokes that are 2mm longer for some reason, fronts as well I believe around that same era. I'll have to dig up my post from the KX group. The other 27 spokes on 2003-2024 KX/KXF rear wheels are the same length (204mm?) as what 1986-2002 KX use. The Moose Racing 2003+ KX 18" rear stainless spoke and stainless nipple set with the 9 longer spokes may still be useable on the earlier hubs (interestingly, after my inquiry, I have now noticed that they list them for '97+ KX rear hubs! The 94-96 or even 90-96 are the same aside from the bearing configuration using an extra bearing on the drive side, I specifically spoke with the sourcing guy from moose / G2 Ergo and told him that I was using a '97-'02 KX rear hub), but I'm not certain yet. I do have a pair here to try this out on. My Excel spoke set in an Excel rim and '97 KX hub weren't even close to bottoming out the nipple at the end of the threads, so I think the Moose spokes with the 9 longer spokes will still work in the 2002 & earlier hubs.
Moose # 140938 / 0211-0042 for the 18-inch KX rear spoke set. Keep in mind these come with stainless steel nipples, not aluminum alloy nipples, if you're looking to save any weight. I might run the stainless steel nipples with OEM front spokes as the heads are slightly shorter height which will help with the very tight fit of a 21x1.6 Nuetech Tubliss bladder/liner assembly on the skinny front rims.
All of these KX 18" rear wheel spokes are going to be heavier than the original KDX spokes which are quite thin gauge. The aftermarket 18 inch rears are all straight gauge spokes unlike the factory butted spokes that are thicker at the threaded end and often thicker at the hub and as well, but the 18 inch aftermarket straight gauge seem to be all we will have available. I much prefer to use the OEM butted front spokes and alloy nipples from the KX applications, but those don't come in the right size for an 18" rear rim conversion unless buying OEM for a late model KX450X/KX250X, which will be quite costly buying individual spokes x 36
I haven't looked at Dubya Wheels yet, but they are very legit as well... They have those custom purple anodized Excel Takasago rims available only through them, like Carson Brown's and my buddy Sebastien Salvant's builds...
https://www.prostuf.com/en/mx-wheels-pr ... green.html
These 1990's/early-2000's Pro Stuf aftermarket hubs sure look nice and fit the application range in question... Obviously if you have a 2004 or newer KX or other Fork swap, you will likely want to go with the hub for that application to get the correct bearing size and spacers. The front rotors have the same bolt pattern through our entire range of interest to present, but the rear rotors changed in 2003+.
Re: Aftermarket wheels / hubs to compliment fork upgrades, etc
I'm waiting for a guy to check to see if he still has a used gold anodized 1990-2002 KX Talon TW607A-G rear hub as it'd be nice to have 3 KX rear wheels for my two KDX220's.
I see Talon sells replacement spacer and bearing kits for every hub they've ever made, and spoke sets intended for these hubs, as do Dubya and KSR wheels here in the USA (Talon is in the UK).
Talon replied to my query and confirmed that their hubs are manufactured with the correct spoke angle for a 3-cross lacing pattern (requiring longer spokes than stock wheels), whereas OEM types are only a 2-cross pattern. I'm curious as to whether the spoke nipple angle in the rims is then slightly off from being intended for OEM type 2-cross lacing? I believe it is.
A 3-cross lacing pattern give a fairly significant amount of added strength to the wheel. Not necessary for an average casual rider, but pro riders and hard enduro riders certainly could use the extra strength... I'd say it's less required with Tubliss and it's 100psi 360 degree inner chamber "rim lock / rim protection" portion, but more required with Mousse inserts.
After weighing my options and having a set of stock length stainless spokes here, I picked up a 2nd used '97-'02 KX rear hub for now. If the guy digs up the Gold Talon '90-'02 rear 6-bolt-rotor hub he had for sale, I'll still likely buy that and be selling a pristine D.I.D. rim KDX/KLX wheelset that I have.
It really sounds like the Talon Rims are the absolute strongest and lightest on the market, stronger than even the top of the line Excel a60 and D.I.D. Dirt Star ST-X (I believe that's the DID equivalent to the a60). Their hubs also seem to be the best in the industry, AND they actually still make them for our older bikes (as well as Envy who I believe I'd read are the actual manufacturers of Talon's hubs).
Dubya Wheels are probably the best place in the USA to get Talon hubs, but the KSR Wheels website also seems to be a reputable and affordable source. (KSR, not to be confused with the KKE brand)
In other news, I was able to track down the guy in Slovakia that was previously selling non-stock color options of clear Excel Takasago Rims decals (the genuine Takasago are transfer decals only available in red and yellow), and snagged 6 wheels worth of purple lettering Excel Takasago Rims logo decals for my two purple & green KDX220's!
I'm a fiend for the purple '96 KDX/KX stylings, so this was a nice finishing touch far cheaper than the custom anodized Excel Takasago rim blanks that Dubya anodizes purple, for a premium upcharge at that... I got 6 sets of black background reflective holographic silver lettering Excel Takasago rim decals thrown in for free with that deal after sharing pictures of my KDX's with the seller! Let me know if anyone wants a set of the holographic decals, one set of 8 will adorn the black rims on my wife' '07 KTM 200 XC-W.
Talon's complete custom wheel builder ordering form tool is quite nice... In my eyes, these will be the best wheels you'll find:
https://talon-eng.co.uk/talon-wheel-builder/
It's an upcharge of + £80.41 for alloy, anodized alloy, or titanium nipples, if one were trying to cut costs, they could forego that option.
Jeftad
Post by Jeftad »
Dubya Wheels says they can build a front wheel for my 1999 KDX220R with modified spacer that will fit. Speedo/odometer cable will not hook up but I just need new wheel. Hope this helps as Dubya was the only company saying "absolutely we can build a front wheel for the KDX."
Jeftad wrote: 11:10 am Dec 10 2025 Dubya Wheels says they can build a front wheel for my 1999 KDX220R with modified spacer that will fit. Speedo/odometer cable will not hook up but I just need new wheel. Hope this helps as Dubya was the only company saying "absolutely we can build a front wheel for the KDX."
That's AWESOME!
Dubya is a fairly impressive wheel company, I definitely get that impression... A few friends have bought wheels or rims through them, all with praise. They also are the ones that offer the custom anodized colors of Excel Takasago blanks... That's where Carson Brown as well as a friend of mine got their purple Excel Takasago rims for their KDX builds!
Very cool that they will make up a custom spacer for the KDX/KLX front axle and fork!
FYI Talon USA has vanished from the internet, no website, and last social media posts at the end of 2024. Come to find out, the parent company, Talon Engineering UK, has basically gone into bankruptcy due to financial troubles since their last ownership change in 2021 or thereabouts.
The company referenced above who actually manufactured the Talon hubs is likely still making their versions of the Talon hubs, although things might be a bit tougher to obtain in the USA for now at least.
I have come to learn this when I was about ready to custom order a set of purple Talon rims, but now, I'll likely be swayed just to order yet another set of polished silver / clear anodized Excel Takasago rims so that all of my wheels match for bike interchangeability reasons between my 3 Kawasaki KDX-based 2-stroke woods bikes... ICS408 21x1.60 36H front and FES410 18x2.15 36H rear. I can find an ICP408 purple front, but no FEP408 rear, only FEP422 rear which I believe only fits certain aftermarket hubs (different spoke angle drilled into rims) in purple. The purple Excels are double the cost of the silver (polished/clear anodized) otherwise identical rims, so unfortunately, I'm sticking to the Excel Takasago silver rims on my next wheel builds!
Ridea200
Country: Usa
Has thanked: 1 time
Been thanked: 16 times
Post by Ridea200 »
Pro-wheel may be worth checking out.
