Panthera E-Start Photos/ Installation pictures.
- Has thanked: 43 times
- Been thanked: 110 times
Billie's Panthera E-Start Photos / Installation pictures
Starter kit on bench pre-assembly and installed. Also, provided parts list. The installation is a snap, especially the mechanical components. All components are well made.
Wiring took longer because I experimented with how I wanted route wires. By the way, the wiring harness has a very nice, thick sheath that should prove very durable.
- Parts_List.jpg (123.63 KiB) Viewed 25278 times
- Parts-Physical_inventory.jpg (2.82 MiB) Viewed 25278 times
- KDX-estarter-Installed.jpg (3.66 MiB) Viewed 25278 times
You will need a flywheel holder to remove the flywheel nut. You do NOT remove the flywheel. You do NOT use the original flywheel nut. You will use a modified nut provided in the starter kit.
You do NOT need a lift, but even an inexpensive lift like this one makes dirt bike maintenance much easier.
- Flywheel_lockers.jpg (4.75 MiB) Viewed 25278 times
- KDX on lift.jpg (3.86 MiB) Viewed 25278 times
I measured the depth between the main gear face and the Figure 8-shaped gasket surface using the same method used by Molly’s. I probably would have made this much more difficult on myself if Molly’s didn’t show me a better method. I made several measurements that averaged 19.56 mm. This is effectively the same as Molly’s reported measurement of 19.58 mm
- Clearance_measurement.jpg (3.17 MiB) Viewed 25278 times
Following measurement verification, you pour the transmission fluid in. My finger and funnel point to where to pour it in. Additionally, one photo shows you the ATF that I used. There were two unopened bottles of this on my garage shelf, so shopping was not necessary. The instructions say you need 300 ml of fluid. My starter system was filled to the filling port with 275 ml of fluid.
Following the first ride with starter use, the fluid will be replaced. The instructions advise removing the starter housing cover to facilitate more thorough cleaning using brake cleaner or equivalent degreaser. It’s my intention to do this because the starter system is not inexpensive.
- Transmission-fluid-1.jpg (3.71 MiB) Viewed 25278 times
- Transmission-fluid_2.jpg (3.61 MiB) Viewed 25278 times
- Transmission-fluid-3.jpg (97.61 KiB) Viewed 25278 times
I’m presently running a total loss system for the starter. I already had a total loss system for all the street legal lighting for everything except the headlight. The headlight still runs on the original lighting coil.
Eventually, I’ll get a regulator-rectifier to charge the batteries for starter system and street legal lighting. Most likely, will pare batteries down to only the Antigravity XPS SC-1 lithium battery. The smaller blue Tusk battery is Ni-CAD and powers the lighting harness the previous owner purchased from Tusk.
- battery.jpg (3.13 MiB) Viewed 25278 times
I temporarily placed the batteries in the air box Panthera battery tray. Once field testing proof is in-hand, I’ll weld some tabs to the frame behind the left-hand number plate so that it is possible to bolt an aluminum plate and battery box in this location. The Antigravity battery is surprisingly small and light.
You may notice the OEM regulator is located behind the aft rail and the CDI is located forward of the air box. These locations are used because I modified the OEM seat pan. My modified seat pan is relatively flat because I removed the “raised rectangle” that’s not felt by your butt because the OEM seat foam is a mile thick. I carved the foam seat way down and have a low, flat seat. The seat pan was reinforced after cutting out the “raised rectangle” using fiberglass mat & resin (don’t remember if I used poly or epoxy resin).
You can see the two charging “pig tails” tails for the two batteries in the airbox. This photo reminds me I need to cap the square to keep the contacts dry and clean.
- KDX-estarter-battery_box.jpg (3.07 MiB) Viewed 25278 times
- KDX_charging_rat_tails.jpg (3.17 MiB) Viewed 25278 times
This video shows me bench testing the Panthera harness, including solenoid using the selected Antigravity battery. The “device” in this test is a 12V dashboard light for an automobile of something like that. I didn’t use the starter motor, but suppose you could IF the two gears in the Figure 8-shaped subassembly of the starter system were removed. I’m overly cautious with electric motors, having seen some burnout when not used carefully enough.
I wanted to keep the Panthera harness plugs clean for eventual use with an on-board charging system. Here you can see I used weather-capable shrink wrap. The two lead plug that lives near the starter assembly (behind the carburetor for now) required ¾ inch shrink wrap tubing. The four lead plug that lives near the battery & solenoid required 1 inch shrink wrap tubing. Notice how the tubing ends were pinched flat to seal the installed tubing. Do this while the tubing is hot. It helps a lot to specifically use weatherproof shrink wrap because it has glue inside it, partially for this purpose. One other note, I used shrink wrap capable of reducing 3:1 (“three to one”).
- KDX-estarter-SHRINK-charging_coil_leads-1.jpg (3.54 MiB) Viewed 25278 times
- KDX-estarter-SHRINK-charging_coil_leads-2.jpg (3.95 MiB) Viewed 25278 times
- KDX-estarter-SHRINK-charging_coil_leads-3.jpg (3.21 MiB) Viewed 25278 times
- KDX-estarter-SHRINK_Reg-Rect_leads_1.jpg (2.71 MiB) Viewed 25278 times
- KDX-estarter-SHRINK_Reg-Rect_leads_2.jpg (880.07 KiB) Viewed 25278 times
These photos show you where I located the yellow Panthera starter button. I wanted to be able to reach it with my left thumb when left hand is on the grip (and potentially holding clutch lever in). As Molly’s clarified, the starter button is always “hot.” There are no safety switches to prevent activate the starter when in gear or with side stand down like factory street-able bikes. I’ll see how many times I make this mistake and then, potentially install a safety switch to work with the clutch lever.
You may be curious why I have so many switches. The reason is three-fold. 1) My KDX is street legal, and therefore lighted, 2) the headlamp and all other street lighting (and horn) run on two different systems (headlight on OEM lighting coil & all else on small Ni-CAD battery), and 3) I like to be able to turn off ALL lights OR just run the headlight).
- Starter_button_Entire_left_bar.jpg (104.37 KiB) Viewed 25278 times
- Starter_button_close-up.jpg (109.73 KiB) Viewed 25278 times
Similar to Molly’s, I used the starter to check engine compression before the gas tank and seat were re-installed (video). Similar to Molly’s, I also obtained 160 psi (photo). This is quite good for a KDX engine.
If you didn’t have an electric starter and want to assure a result that’s more repeatable than kicking, then you can use an electric drill or impact wrench (don’t pound) or similar motor to spin the engine fast using the flywheel nut.
- KDX-compression_gage.jpg (168.39 KiB) Viewed 25267 times
This video demonstrates how well the Panthera electric starter works. The video documents two engine starts made in succession. Between the first and second starts, the engine was shut off using the red kill switch button located on the right-hand bar grip.
In both engine starts, you’ll hear the engine start very, very quickly. This is because the little starter motor really packs a punch!
I’ll get a chance to ride in the next few days and tell you how much fun it is / isn’t. All in all, I’m anticipating it will be fun.
assquatch20
- Has thanked: 11 times
- Been thanked: 3 times
Re: Panthera E-Start Photos/ Installation pictures.
I love that they're sending a detailed parts list. I really need to get one of these kits.
I meant to include the exploded diagram with the parts list. So, it' here. The parts list. diagram, & received parts match (e.g., are correct).
The required toos list provided with the starter kit identifies an item that is not used. The unnecessary tool is a drill bit (e.g., 3/4-inch was it?).
- 20251031_184423.jpg (1.48 MiB) Viewed 25237 times
- 20251031_184454.jpg (1.39 MiB) Viewed 25237 times
- SpruceItUp
- Has thanked: 135 times
- Been thanked: 61 times
I just ordered a kit from them. Not cheap, but will be awesome to have!! After reading the posts here I just knew I had to get one hahaha
I'm sure it will take few months to arrive, but I suppose I'll soon find out!
'92 KDX200
'25 CRF300L Rally
'05 CR125R
'25 CRF300L Rally
'05 CR125R
Spruce, that's cool!!! Yeah, it'll be 4 to 6 months wait. Production is the bain of tiny specialty mechanical designers. While "expensive," the design is clever, robust, & well-made. And maybe, all the tarrif stuff will be settled & reasonable by then.
- SpruceItUp
The design seems great from what I have seen! Can't wait to get my hands on it.
Hopefully the tariff situation calms down soon. But ya never know.
'92 KDX200
'25 CRF300L Rally
'05 CR125R
'25 CRF300L Rally
'05 CR125R
tosaw
- Has thanked: 15 times
- Been thanked: 18 times
Re: Billie's Panthera E-Start Photos / Installation pictures
Hey Billie, just curious if you ever eliminated the Tusk battery. I'm planning on doing the same to my plated 90. I've ordered the Panthera kit, upgraded lighting coil and a Trail Tech RR. Although I could live with a total loss system, I like the idea of a self charging system.billie_morini wrote: 10:37 pm Oct 31 2025 I’m presently running a total loss system for the starter. I already had a total loss system for all the street legal lighting for everything except the headlight. The headlight still runs on the original lighting coil.
- SpruceItUp
I’m currently working on getting my 92 plated and I have pretty much the same idea. I’m sure with the upgraded coil it won’t be an issue to charge the battery. I can’t wait to have my bike plated with an e start.tosaw wrote: 04:45 pm Feb 04 2026 Hey Billie, just curious if you ever eliminated the Tusk battery. I'm planning on doing the same to my plated 90. I've ordered the Panthera kit, upgraded lighting coil and a Trail Tech RR. Although I could live with a total loss system, I like the idea of a self charging system.
I’d like to wire in a key ignition as well. Still need to work on turn signals & brake lights for my bike, though I am waiting on dirt legal’s stuff to go through so I can get my plate.
Sorry hahaha! Just happy to see someone is doing something similar to their E series as I am.
'92 KDX200
'25 CRF300L Rally
'05 CR125R
'25 CRF300L Rally
'05 CR125R
I've not made the step to charge the starter battery on-board with rectifier / regulator. Other more lengthy projects required precedence
- Has thanked: 309 times
- Been thanked: 144 times
I, personally, would not even ever set it up as a total loss system if I were to want the Panthera electric start kit. From day one I would have that battery charging off of the onboard electrical system. I always wire up a DC rectifier or regulator-rectifier for higher output LED headlight use on my KDX builds, for the few odd occasions where you end up out on the trail for far longer than you plan and the sun sets on you, as well as the intentional night rides, which are quite fun... Or even just running from camp at night down to the trailhead restrooms at night or early AM where we ride in Daniel Boone National Forest Kentucky.
The KDX came with a somewhat functional headlight, may as well improve upon it and may as well link the E-Start battery to it also!
