KDX200SR
Goatfish
- Country: Australia
Re: 1990 KDX200SR
What a neat rebuild!
I am curious to know what the oil tank looks like and where it goes.
hi-def
- Country: New Zealand
Re: 1990 KDX200SR
I don't have pics at hand of the whole tank but you can see it here, it sits on the right hand side of the frame underneath the fuel tank.
And here is the oil pump just below the intake with a hose running to the inlet manifold.
- Has thanked: 134 times
- Been thanked: 36 times
Re: 1990 KDX200SR
What is the knob?
Thanks for the pics.
hi-def
Re: 1990 KDX200SR
In the bottom pic? That is the idle adjustment on the PE28 carby, quite convenient but not necessary.
Re: 1990 KDX200SR
OK, yet another tidbit we didn't see in the USA.
Re: 1990 KDX200SR
Great post with plenty of information , I have also acquired the sr model with the upside down forks , do you have any information as to what they are , I am looking at rebuilding mine
hi-def
Re: 1990 KDX200SR
Cheers!1fletch wrote: 02:01 pm Nov 02 2021 Great post with plenty of information , I have also acquired the sr model with the upside down forks , do you have any information as to what they are , I am looking at rebuilding mine
Re: 1990 KDX200SR
1fletch, welcome to kdxrider.net. Start a new thread and a few of us can help you out some. I have had some apart and rebuilt them before more than once.
hi-def
Re: 1990 KDX200SR
I'm a bit behind on progress so here's an update.
After the engine went back in it was looking good, break in went well and it pulls hard, lots of fun.
hi-def
Re: 1990 KDX200SR
Then I decided I wanted to swap to the bigger (standard) carb on the E model from the 28mm SR one, so started sourcing parts.
hi-def
Re: 1990 KDX200SR
The SR has an oil injection port on its inlet rubber and the replacement one does not.
hi-def
Re: 1990 KDX200SR
Next up was the valve, I filed a spare down using a drill and can now insert it inline before the carb.
hi-def
Re: 1990 KDX200SR
A couple extras were added after
Some reeds
Some reeds
- Has thanked: 2 times
Re: 1990 KDX200SR
Heck yeah! Looks nice!
Re: 1990 KDX200SR
i found that float bowl on ebay, doesn't look like it has a provision for any sort of overflow tube, or a removable bowl plug. If your float ever sticks open, it'll likely fill your crankcase with fuel before it comes out of the breather hoses on the carb.
hi-def
Re: 1990 KDX200SR
Yeah it's not the best design, unfortunately my original metal bowl will do the same due to a previous owners handiwork :(
PeterW
Re: 1990 KDX200SR
EDIT: (what you typed was edited out)
Please leave kxrider.net out of the copyrighted manual discussion as I mentioned earlier in the thread.
hi-def
Re: 1990 KDX200SR
My KDX is still going strong
Re: 1990 KDX200SR
Looking good!
