KDX200SR
Goatfish
Country: Australia
Re: 1990 KDX200SR
Post by Goatfish »
What a neat rebuild!
I am curious to know what the oil tank looks like and where it goes.
hi-def
Country: New Zealand
Re: 1990 KDX200SR
Post by hi-def »
I don't have pics at hand of the whole tank but you can see it here, it sits on the right hand side of the frame underneath the fuel tank.
And here is the oil pump just below the intake with a hose running to the inlet manifold.
Has thanked: 173 times
Been thanked: 43 times
Re: 1990 KDX200SR
What is the knob?
Thanks for the pics.
hi-def
Re: 1990 KDX200SR
Post by hi-def »
In the bottom pic? That is the idle adjustment on the PE28 carby, quite convenient but not necessary.
Re: 1990 KDX200SR
OK, yet another tidbit we didn't see in the USA.
1fletch
Country: Uk
Re: 1990 KDX200SR
Post by 1fletch »
Great post with plenty of information , I have also acquired the sr model with the upside down forks , do you have any information as to what they are , I am looking at rebuilding mine
hi-def
Re: 1990 KDX200SR
Post by hi-def »
1fletch wrote: 02:01 pm Nov 02 2021 Great post with plenty of information , I have also acquired the sr model with the upside down forks , do you have any information as to what they are , I am looking at rebuilding mine
Cheers!
Re: 1990 KDX200SR
1fletch, welcome to kdxrider.net. Start a new thread and a few of us can help you out some. I have had some apart and rebuilt them before more than once.
hi-def
Re: 1990 KDX200SR
Post by hi-def »
I'm a bit behind on progress so here's an update.
After the engine went back in it was looking good, break in went well and it pulls hard, lots of fun.
hi-def
Re: 1990 KDX200SR
Post by hi-def »
Then I decided I wanted to swap to the bigger (standard) carb on the E model from the 28mm SR one, so started sourcing parts.
hi-def
Re: 1990 KDX200SR
Post by hi-def »
The SR has an oil injection port on its inlet rubber and the replacement one does not.
hi-def
Re: 1990 KDX200SR
Post by hi-def »
Next up was the valve, I filed a spare down using a drill and can now insert it inline before the carb.
hi-def
Re: 1990 KDX200SR
Post by hi-def »
A couple extras were added after
Some reeds
Been thanked: 17 times
Re: 1990 KDX200SR
Hey that's some great work! I like that clear float bowl!
Re: 1990 KDX200SR
Heck yeah! Looks nice!
Re: 1990 KDX200SR
i found that float bowl on ebay, doesn't look like it has a provision for any sort of overflow tube, or a removable bowl plug. If your float ever sticks open, it'll likely fill your crankcase with fuel before it comes out of the breather hoses on the carb.
hi-def
Re: 1990 KDX200SR
Post by hi-def »
Yeah it's not the best design, unfortunately my original metal bowl will do the same due to a previous owners handiwork :(
PeterW
Country: Australia
Re: 1990 KDX200SR
Post by PeterW »
EDIT: (what you typed was edited out)
Please leave kxrider.net out of the copyrighted manual discussion as I mentioned earlier in the thread.
hi-def
Re: 1990 KDX200SR
Post by hi-def »
My KDX is still going strong
Re: 1990 KDX200SR
Looking good!
