1989 KDX200 Sheared Clutch Pressure Plate
btoldi
I just got a project 1989 KDX200 and the guy said the there was an issue with the clutch. When I took it apart I found out the clutch pressure plate (or 13086-1060 WHEEL-CLUTCH from the parts diagram) had basically sheared off the entire middle section, as you can see in the picture below. I have worked on quite a few bikes but have never seen this. I am assuming the previous owner just didn't put the clutch back together correctly, but I just want to see if anyone else has had this issue before. I just want to make sure there is not something worse going on. Thanks in advance.
- KDX200 Pressure Plate.jpg (536.17 KiB) Viewed 7057 times
- Been thanked: 19 times
Re: 1989 KDX200 Sheared Clutch Pressure Plate
Looks like installation error on his part.
- Has thanked: 184 times
I don't remember anyone reporting that before.
btoldi
Yeah, that's what I figured. Unfortunately this is one of those parts that I guess they don't manufacture any more so I'll just be checking eBay until I find one.
btoldi
Does anyone know exactly what this piece is called? From the part diagram its called a Wheel-Clutch, but I've heard people call it the clutch pressure plate. Just trying to refine my parts search.
- ss109
- Has thanked: 33 times
- Been thanked: 53 times
It's called a pressure plate. I might have a spare one if you're interested.
btoldi
Yes, that would be great if you do! I've been looking everyday for almost a month now and can't seem to find one that fits my year bike.
This Kawasaki 13086-1060 WHEEL-CLUTCH Not Available fits the following models and components:
Kawasaki Motorcycle 1992 KDX200 - KDX200-E4 Clutch
Kawasaki Motorcycle 1989 KDX200 - KDX200-E1 Clutch
Kawasaki Motorcycle 1990 KDX200 - KDX200-E2 Clutch
Kawasaki Motorcycle 1991 KDX200 - KDX200-E3 Clutch
Kawasaki Motorcycle 1993 KDX200 - KDX200-E5 Clutch
Kawasaki Motorcycle 1989 KX125 - KX125-G1 Clutch
Kawasaki Motorcycle 1994 KDX200 - KDX200-E6 Clutch
btoldi
Thanks for the info. I just added those to my searches.
bigdhusker
You might give Fredette Racing a call (708) 946-0999, he has a lot of NOS parts on hand that you can't get anywhere else
btoldi
Got lucky and found one on ebay. Thanks for all the help!
Good job!
