Lectron Ordered!
DenverKdxRider
Re: Lectron Ordered!
Post by DenverKdxRider »
Did you figure out how to get the slack out of the cable? I adjusted both ends to almost the very end and there's still a little slack! I contacted Lectron and they said that I should get the 8mm cable..why wouldn't they send the 8 mm in the first place??
VTMTcowboy
Post by VTMTcowboy »
Through some other KDXers, I will eventually order a Barnett custom cable, which is about $50-60, but for now I am going to live with it. I am not keen on how much the cable is bent at the point of contact to the carb, but others have reported no issues over extended periods of use.
