Water pump shaft
andytom1969
Water pump shaft
Post by andytom1969 »
Hi all. My 250sr is getting water into the case past the water pump seals because the shaft is quite badly scored. The shaft is no longer available. Does anyone have any ideas for repairing it?
Re: Water pump shaft
With no availability, as I said in the previous post, may be able to have a shop fill the score and turn the shaft back down to dimension. Not sure if JB weld would hold up in that application
Post by kdxsully »
JB weld won’t work.
Has thanked: 6 times
Been thanked: 3 times
Negative on the JB weld. I would tig it up & put on a lathe. After it gets machined down, you could polish it with emory cloth while spinning.
Post by kdxsully »
Molly's 70 wrote: 02:48 pm Jan 14 2020 Negative on the JB weld. I would tig it up & put on a lathe. After it gets machined down, you could polish it with emory cloth while spinning.
Wouldn’t it wear down again pretty fast without the chrome?
kdxsully wrote: 10:39 pm Jan 14 2020
Maybe, but it would work for quite a while. I would have to look at a good filler rod selections.
