motogoalie1
Posts: 28 Joined: 11:37 am Dec 25 2013
Post
by motogoalie1 » 05:40 pm Feb 26 2017
Well, the pins pretty much welded themselves to my caliper and its fuxd.
Ive sourced a 1995 KX500 caliper shell and I'm PRETTY sure it will fit. Anyone know for sure? I know this caliper was ubiquitous to a bunch of bikes over the early 90s...I think the entire MX line and some street bikes in the late 90s.
Here's to using antisieze on critical assembly bolts and a TORQUE wrench.
Posts: 14677 Joined: 06:45 am Nov 01 2004
Has thanked: 71 times
Been thanked: 20 times
Post
by KDXGarage » 01:48 am Feb 27 2017
Did you use anti-seize and a torque wrench?
Have you tried penetrating oil?
Tyl3r
Posts: 1349 Joined: 06:51 pm Nov 26 2012
Post
by Tyl3r » 08:03 am Feb 27 2017
For a direct fit, the H Series kdx rear caliper is shared with these year/models (doesn't look like a 95 KX500 is the same):
1989 KX125-G1 KX125 REAR BRAKE
1989 KX250-G1 KX250 REAR BRAKE
1989 KX500-E1 KX500 REAR CALIPER
1990 KX125-H1 KX125 REAR CALIPER
1990 KX250-H1 KX250 REAR CALIPER
1990 KX500-E2 KX500 REAR CALIPER
1991 KDX250-D1 KDX250 REAR BRAKE
1991 KX125-H2 KX125 REAR CALIPER
1991 KX250-H2 KX250 REAR CALIPER
1991 KX500-E3 KX500 REAR CALIPER
1992 KDX250-D2 KDX250 REAR BRAKE
1992 KX125-J1 KX125 REAR CALIPER
1992 KX250-J1 KX250 REAR CALIPER
1992 KX500-E4 KX500 REAR BRAKE (KX500-E4-E5-E6-E7)
1993 KDX250-D3 KDX250 REAR BRAKE
1993 KX125-J2 KX125 REAR CALIPER
1993 KX250-J2 KX250 REAR CALIPER
1993 KX500-E5 KX500 REAR BRAKE (KX500-E4-E5-E6-E7)
1994 KDX250-D4 KDX250 REAR BRAKE
1995 KDX200-H1 KDX200 REAR BRAKE
1996 KDX200-H2 KDX200 REAR BRAKE
1997 KDX200-H3 KDX200 REAR BRAKE
1997 KDX220-A4 KDX220R REAR BRAKE
1998 KDX200-H4 KDX200 REAR BRAKE
1998 KDX220-A5 KDX220R REAR BRAKE
1999 KDX200-H5 KDX200 REAR BRAKE
1999 KDX220-A6 KDX220R REAR BRAKE
2000 KDX200-H6 KDX200 REAR BRAKE
2000 KDX220-A7 KDX220R REAR BRAKE
2001 KDX200-H7 KDX200 REAR BRAKE
2001 KDX220-A8 KDX220R REAR BRAKE
2002 KDX200-H8 KDX200 REAR BRAKE
2002 KDX220-A9 KDX220R REAR BRAKE
2003 KDX200-H9 KDX200 REAR BRAKE
Posts: 3557 Joined: 06:03 pm Oct 31 2012
Been thanked: 8 times
Post
by bufftester » 03:29 pm Feb 27 2017
Jason wrote: Did you use anti-seize and a torque wrench?
+1 and heat. Had a stuck pin on my 95 RMX250 and used oil and heat to work it loose, cheaper than buying a new caliper if it works, and if it doesn't not much lost.
motogoalie1
Post
by motogoalie1 » 08:02 pm Feb 27 2017
Tried everything. It's smoked. I'm going to have to cut it out and drill it out. Its a mess.
Too bad on the KX 500 sourcing then. There's nothing out there other than beat to **** fleabay junk wildly overpriced.
Im going to bring that KX5 caliper in the house and see what I need to do to make it work.
Post
by KDXGarage » 08:54 pm Feb 27 2017
Even though the part number is not the same, it might work. It may merely have a different sized piston. Check it out.
motogoalie1
Post
by motogoalie1 » 01:54 pm Mar 19 2017
Deal fell through. Still stuck for a solution.
Post
by KDXGarage » 10:38 pm Mar 19 2017
get em out or get another one
