Voltage regulator...
Rollingmenace
Post by Rollingmenace »
Ok here goes I have an 89 Kdx 200 ... From what I've seen online and found the 89 does not have a voltage regulator.. I keep burning headlight bulbs in mine and I'm planning on setting it up as a dual sport by running a brake light.. Here is the million dollar question .. How hard would it be to install a regulator and would it help with the burning up of headlights.. Has anyone done this before???
Has thanked: 10 times
Been thanked: 17 times
Re: Voltage regulator...
Yes sir. It's been done. I just used an H series KDX VR.
Rollingmenace
I have a couple spare regulators off of my Honda 250r threre just simple two wire regs think they will work if wired in???
I don't see why not. Give it a try. Pay attention to polarity. If you wire it backwards you will probably toast the lighting coil.
Has thanked: 95 times
Been thanked: 22 times
Will the stock 1990 to 1994 part work?
Jaguar
Country: Ecuador
Post by Jaguar »
I think all KDXes have a regulator because they don't have a battery (which would serve to limit the voltage)
Rollingmenace
Jason
From what I'm seeing it's common to use the 90-94 regulators in the 89 bikes
That is correct. That's what I did.
Jaguar, USA 1989 models did not, but 1990 + did.
Jaguar
Country: Ecuador
Post by Jaguar »
Jason, are you saying all the E series did not have it? (my '89 int'l E had it)
Did they not have headlights?
david
Country: UNITED STATES
Post by david »
They have lights, you just have to have both the front and back bulb in the circuit to use up the voltage. My KDX175 is the same way. If you lose one bulb the other will get popped by a voltage overload.
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
