Slow leak from transmission drain plug
sthoward
Hi all, I got my basket case KDX200 together and running, and now I've noticed a slow leak from the drain plug. The drain plug is the correct one. The previous owner put two crush washers on there that were not the right part, so I got the correct one from my Kawasaki dealer but she's still leaking. Is this common with the KDX? Any easy solutions?
Thanks
Thanks
canamfan
I wrap the threads with thread tape or use the liquid thread tape, works for me. If that doesn't work you might look closer for a leak somewhere else, could be running down.
- Has thanked: 126 times
- Been thanked: 33 times
Re: Slow leak from transmission drain plug
Any chance the threads are a little stripped or damaged?
Did you use a torque wrench?
- C George
If the threads are messed up , this product works good . Everything has to be clean and dry.
05 KDX-220R / 06 KDX-225R / Maxima 927 / Millenium Tech / Ron Black / PC , FMF / Many 220 engine mods / 40 + yrs. of riding dirt bikes
Is that going to be suitable for frequent oil changes??
- Sullyfam
IMO - Don't do anything that makes removal difficult.
Sounds like the threads are messed up. Use pipe compound or Teflon tape. Is that doesn't work you can try a Heli-coil.
- C George
Good thought ,,,, a helicoil has to be tougher.Jason wrote:Is that going to be suitable for frequent oil changes??
Aluminum drain plug holes are a pia.
sthoward
Plumber's tape did the trick, no more drip drip drip. Thanks!canamfan wrote:I wrap the threads with thread tape or use the liquid thread tape, works for me. If that doesn't work you might look closer for a leak somewhere else, could be running down.
I've never had to do that before on any previous bike, and given the condition the bike was in when I bought it (non-running, poorly maintained) I suspect the threads are a little messed up.
Thanks for reporting back.
eprovenzano
Love it when the OP reports back problem solved...sthoward wrote:Plumber's tape did the trick, no more drip drip drip. Thanks!canamfan wrote:I wrap the threads with thread tape or use the liquid thread tape, works for me. If that doesn't work you might look closer for a leak somewhere else, could be running down.
1991 KDX basket case... being rebuilt
2001 KTM EXC 380... two stroke heaven
2000 KTM EXC 300, son's
1993 Kawaski Bayou 400 4x4
2008 Yamaha Vstar 1100 Silverado
sthoward
It's the least I could do in return for the help I've received on this forum. kdxrider.net ROCKS!eprovenzano wrote:Love it when the OP reports back problem solved...sthoward wrote:Plumber's tape did the trick, no more drip drip drip. Thanks!canamfan wrote:I wrap the threads with thread tape or use the liquid thread tape, works for me. If that doesn't work you might look closer for a leak somewhere else, could be running down.
