With the years, does Clark tank tends to yellow like the KTM ?
Clarke natural gas tank
- ced64k
I'm looking for a picture of the Clarke gas tank in natural color fitted on a KDX 200 H. Not the oversize but the standard size. As a fashionista, I hesitate between the black and natural
- diymirage
Re: Clarke natural gas tank
one thing to consider is the dye used in the oil you prefer, that might have an effect on tank colour as well
-1997 KDX 220 project bike
- ced64k
- dingerjunkie
That is absolutely bad-a$$. Due to different donor-bikes, the tank on my KDX250 has faded at a different rate than the rest of the plastic I'm using. Hello black tank.
Theory and Practice are ALWAYS identical...theoretically...
http://www.fire-fx.net
...your theater is on...
- ced64k
- Has thanked: 196 times
- Been thanked: 94 times
Updated version (a few years newer than the vid above), using Rit Pro Line dye, salt, vinegar, and dishwashing detergent:
(pardon the goofy helmet/goggles persona of the guy in the vid!)
Now in addition to my black Clarke tank, Black Preston Petty Muder front fender, and black 94-98 KX125/250 rear fender slight mods to fit under seat area with dremel and heat gun), I can dye my H series 95-06 side panels and shrouds black as well.... I thought my only option was green UFO!
I think I'll try both, trying to break up the excessive green and white accent color scheme to give my bike a new refreshed appearance without buying expensive vinyl overlays that'll just get torn up...
I have a KDX175 headlight/number plate, but I think I might dye a Preston Petty headlight/number plate black so that my bike is black down the top center, and green on the side panels and shrouds or just green on the frame...
I wanted an '88 KDX200, but I love my '99 KDX220R H-series so much, I just wanted to add a little bit of retro nostalgia aesthetic to the front end and black it out and keep riding this brilliant machine... aside from the OEM 220 piston woes fixed by a Wossner or Wiseco, I think the KDX220R is quite possibly the best most versatile recreational trail bike of all time, especially with a Ron Black modded head and Ron Black modded/prepped Keihin Air Stryker carb, + FMF Gnarly Desert pipe... and Neutech Tubliss system & upgraded lighting stator. doesn't get any better that, I much prefer it to the KTM 200's which only want to go like an MX bike even with a heavy flywheel weight...
