Kdx200 ktm exc hybrid
loulou123
This is my 1989 kdx200 hybrid using a 2003 ktm exc125 frame http://s1373.photobucket.com/user/Loulo ... sort=1&o=0
- diymirage
Re: Kdx200 ktm exc hybrid
-1997 KDX 220 project bike
newbbewb
- 6 Riders
That right there is a way to make KTMs NOT suck
Actually a sweet bike, what did it take to build that?
newbbewb
is that an H series 200 engine? what carb? do you know how much it weighs?
canamfan
loulou123
It's all ktm part from the engine and carb. It's a e series engine and standard carb. The fame is 2003 exc 125 only little modification to engine mounts on frame. The subframe is 2004 exc 450 as well as the tank the airbox is 2005 exc 200. The swingarm forks and rear shock are 2010 sxf 250. The expansion pipe is ktm 200 exc 2006. The weight is 94kg wet.
loulou123
- diymirage
where did you get all that, raided a KTM junkyardloulou123 wrote:It's all ktm part from the engine and carb. It's a e series engine and standard carb. The fame is 2003 exc 125 only little modification to engine mounts on frame. The subframe is 2004 exc 450 as well as the tank the airbox is 2005 exc 200. The swingarm forks and rear shock are 2010 sxf 250. The expansion pipe is ktm 200 exc 2006.
loulou123
Already had a few bit and a kdx the rest of the bit come for good old eBay.
- Gotanubike
Cool! How did you make that pipe work on an E series engine(Also which pipe is it?) It didn't hit the KIPS governor rod??
1990 KDX200
loulou123
No work done to the cases just two shim ever side because the swing arm gap is bigger. If you use a ktm swing arm up to 2006 the swingarm bolts are the same as kdx I'm using a later one so just had to make up some sleeves so it fit. The front pipe is a 2006 ktm 200 had to make up an adapter to take the bigger bore of the pipe and slightly dent the pipe to clear the rod. The bike runs perfect with the pipe only a to up the jet by 1.
- marrk_us
I love it! A KTM that doesn't "Keep Taking Money" and you won't find yourself on the trail "Kicking Til Morning"
newbbewb
dammit man! I have a good shape but POS 89 kx with E series kdx engine. This thing hauls ass EVERYWHERE. I can't honestly imagine that setup. stop posting this stuff.
- ICRage42
indeed its like vintage porn
but recut to fit the times
- Has thanked: 71 times
- Been thanked: 20 times
WOW!! Congratulations!! Nice bike.
