Kdx200 ktm exc hybrid
loulou123
Post by loulou123 »
This is my 1989 kdx200 hybrid using a 2003 ktm exc125 frame http://s1373.photobucket.com/user/Loulo ... sort=1&o=0
diymirage
Re: Kdx200 ktm exc hybrid
Post by diymirage »
sweet
-1997 KDX 220 project bike
newbbewb
Post by newbbewb »
booooIIINNNGGG!
93 kdx200-Highly modified
89 kx125/kdx200E engine
Buelldustin@gmail.com
6 Riders
Post by 6 Riders »
That right there is a way to make KTMs NOT suck :lol:
Actually a sweet bike, what did it take to build that?
newbbewb
Post by newbbewb »
is that an H series 200 engine? what carb? do you know how much it weighs?
canamfan
Post by canamfan »
I can't get the link to work, whats it take to access it?
loulou123
Post by loulou123 »
It's all ktm part from the engine and carb. It's a e series engine and standard carb. The fame is 2003 exc 125 only little modification to engine mounts on frame. The subframe is 2004 exc 450 as well as the tank the airbox is 2005 exc 200. The swingarm forks and rear shock are 2010 sxf 250. The expansion pipe is ktm 200 exc 2006. The weight is 94kg wet. Image
loulou123
Post by loulou123 »
My racing couple weeks back. Image Image
diymirage
Post by diymirage »
loulou123 wrote:It's all ktm part from the engine and carb. It's a e series engine and standard carb. The fame is 2003 exc 125 only little modification to engine mounts on frame. The subframe is 2004 exc 450 as well as the tank the airbox is 2005 exc 200. The swingarm forks and rear shock are 2010 sxf 250. The expansion pipe is ktm 200 exc 2006.
where did you get all that, raided a KTM junkyard :lol:
loulou123
Post by loulou123 »
Already had a few bit and a kdx the rest of the bit come for good old eBay.
Has thanked: 10 times
Been thanked: 17 times
Nice work! No work needed to be done to the swingarm or engine cases?
Gotanubike
Post by Gotanubike »
Cool! How did you make that pipe work on an E series engine(Also which pipe is it?) It didn't hit the KIPS governor rod??
1990 KDX200
loulou123
Post by loulou123 »
No work done to the cases just two shim ever side because the swing arm gap is bigger. If you use a ktm swing arm up to 2006 the swingarm bolts are the same as kdx I'm using a later one so just had to make up some sleeves so it fit. The front pipe is a 2006 ktm 200 had to make up an adapter to take the bigger bore of the pipe and slightly dent the pipe to clear the rod. The bike runs perfect with the pipe only a to up the jet by 1.
loulou123
Post by loulou123 »
Image Image
factoryX
Post by factoryX »
207lbs wet :kick:
marrk_us
Post by marrk_us »
I love it! A KTM that doesn't "Keep Taking Money" and you won't find yourself on the trail "Kicking Til Morning" :partyman:
newbbewb
Post by newbbewb »
dammit man! I have a good shape but POS 89 kx with E series kdx engine. This thing hauls ass EVERYWHERE. I can't honestly imagine that setup. stop posting this stuff. :razz:
ICRage42
Post by ICRage42 »
indeed its like vintage porn :lol: but recut to fit the times :partyman:
Has thanked: 71 times
Been thanked: 20 times
WOW!! Congratulations!! Nice bike.
