Mystery Nipple!
UI Vandal
Mystery Nipple!
Post by UI Vandal »
While refreshing the top end of my bike I discovered a mystery nipple. It had no hose attached and was a bit gunked up.
Should a hose from the carb attach ere? Should there be an additional hose attached?
My KIPS area is also missing these two bolts.
What function do they serve?
JoKDX220r
Mystery Nipple!
Post by JoKDX220r »
The "nipple" is used to plug the case breather hose...
The 2 bolts, if you mean the ones with the number "7" on them are used as stoppers if I remember correctly..
Tedh98
Been thanked: 2 times
Mystery Nipple!
Post by Tedh98 »
JoKDX220r wrote:The "nipple" is used to plug the case breather hose...
That hose should then go up to and inside the airbox.
UI Vandal
Mystery Nipple!
Post by UI Vandal »
Thank you! Guess I'll grab some fuel line hose then.
Been thanked: 19 times
Mystery Nipple!
The breather hose doesn't go inside the air box, it goes into the little "hoop" on the bottom of the air box by the frame rail.
Tedh98
Mystery Nipple!
Post by Tedh98 »
Slick_Nick wrote:The breather hose doesn't go inside the air box, it goes into the little "hoop" on the bottom of the air box by the frame rail.
Interesting. That wasn't how it was set-up on the '97 and '01 200's I had.
diymirage
Re: Mystery Nipple!
Post by diymirage »
i've heard of people running that breather hose as well as all the carb vent hoses into the airbox in order to cross deeper waters
on both my bikes this breather hose was run down the engine and tuck in by the rear shock just like the carb hoses
-1997 KDX 220 project bike
Has thanked: 195 times
Been thanked: 52 times
Re: Mystery Nipple!
In stock form, there is a hole in the airbox of a few KDX's to place the crankcase breather tube.
rbates9
Mystery Nipple!
Post by rbates9 »
Mine has the breather going up to the air box.
Mystery Nipple!
According to the factory "hose and wire routing diagram" that's where its supposed to go, into that hoop on the bottom of the airbox.
Mystery Nipple!
On page 1-22 of the 1997 manual, I am seeing it with an arrow, mentioning "to the airbox".
The hole in the airbox is for the crankcase vent hose.
Kroynon
Re: Mystery Nipple!
Post by Kroynon »
On the 91-94 250s it also goes into the airbox. I had it there until I bailed on a brutal hill climb and the bike was upsidedown on the face of the hill for a while as I climbed back up to retrieve it. By the time I got there most of the case oil had poured out the breather into the air box.
Now I route the hose up the frame and back down under the engine with the carb vents in a loop to avoid this from happening again.
rbates9
Mystery Nipple!
Post by rbates9 »
Jason wrote:On page 1-22 of the 1997 manual, I am seeing it with an arrow, mentioning "to the airbox".
My bike was stock when I got it and it went to the air box, and the best I can recall the 95 I had years ago also went to the air box. I can't see why they would have it vent to the ground. If it was in the wide open air then it would suck in crap too much.
Re: Mystery Nipple!
Kroynon wrote:On the 91-94 250s it also goes into the airbox. I had it there until I bailed on a brutal hill climb and the bike was upsidedown on the face of the hill for a while as I climbed back up to retrieve it. By the time I got there most of the case oil had poured out the breather into the air box.
Have you considered not looping it out and leaving it upside down as a way "to avoid this from happening again"?? :grin:
Kroynon
Re: Mystery Nipple!
Post by Kroynon »
Haha... That would be too easy but may be worth a try. :lol:
