1984 kdx200 piston
freight
1984 kdx200 piston
Help, anyone have a picture of a oem standard sized piston on a 1984 kdx200? just want to compare it to mine thanks Freight
freight
Re: 1984 kdx200 piston
the piston that came out of this bike has about a 8mm hole drilled in the rear of it. I thought there was a couple of large ports supposed to be there. just need to see whats supposed to be in this engine. 84 kdx200. any help at all appreciated. Freight
- Has thanked: 159 times
- Been thanked: 39 times
Look at my post from a few days ago, piston related thread.
- Has thanked: 10 times
- Been thanked: 17 times
You're talking about the hole on the intake side, yes? Earlier pistons generally had just a small hole drilled there. Later pistons usually have a window. I would guess that your 84 stock piston would probably just have the small hole drilled on the intake side. There is not a lot of information that I have found regarding the amount of difference this makes, but I can tell you whatever difference there is is not noticeably on my 89. I have run both, and there is no discernible seat-of-the-pants difference.
freight
cool that's what had me concerned that it was the wrong piston. thanks for the help guys.
