1st Hybri Attempt. Thoughts????
Rjcapt
Post by Rjcapt »
I have a 97 KDX200 and an 01 KX125 in the garage that I am using.
The KX swingarm looks different from the ones I have read about on this forum. It doesn't have any excess in the left bearing area to trim for clearance. The right side looks similar to the ones I have seen here.
Is this unusual, or am I missing something here?
My solution is to trim the case.
I have read several posts discussing how this is a "bad" idea, but I'm not so sure. I'm going to split the cases so I can mill it on my Bridgeport anyway, so I will put a full length sleeve in both sides of the case while it's apart.
That being said, I didn't engineer the thing, so I'm making some assumptions here, but I don't see that there's much, if any stress on that part of the case. The load is carried by the frame. The case acts as a spacer only to capture the bearing bushings.
Any thoughts or suggestions here?
Thanks
Pete
Been thanked: 19 times
You should be fine. Especially since you're going to run a sleeve in it for added strength. I think most modify the Swingarm because it's easier.
doctord23
Post by doctord23 »
That is strange. I was able to trim 9mm off of both sides of my '02 swingarm and bushings.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1988 White KDX 200C3
1984 KX500 (original owner)
1996 Honda Magna V4
2017 Honda Africa Twin DCT
frankenschwinn
Post by frankenschwinn »
doctord23 wrote:That is strange. I was able to trim 9mm off of both sides of my '02 swingarm and bushings.
+1
scheckaet
Post by scheckaet »
pics would be helpful ..
Rjcapt
Post by Rjcapt »
scheckaet wrote:pics would be helpful ..
Agreed. I'm about 1000miles away from my bike right now, but I'll try to post some this weekend.
Thanks
Pete
Rjcapt
Post by Rjcapt »
frankenschwinn
doesnt look like an 01...
frankenschwinn
This is an 02. same as 01
Rjcapt
Post by Rjcapt »
No, it doesn't look like an 01. Anybody know what it is? I'm going to run the vin to see what's going on, but I have an 01 frame and they are identical.
Last resort is 01 swing arms are running $25 so I'll probably just get another one.
Thanks
Rjcapt
Post by Rjcapt »
It doesn't look like a 2001 because it's a 1997....
Oh well
KarlP
Post by KarlP »
Are you currently riding the '97 KX125 and like it?
i had a '95 for a while and it was a pretty good ride in the woods, except for the way the motor performed.
A KDX200 motor in the '97 KX chassis would be a great woods bike.
'08 KTM200xc
KX100 for the boy
Rjcapt
Post by Rjcapt »
No, the KX came as a roller with a blown up engine. I've never ridden a KX of any vintage.
I think I'll just do the 97 and see if I like it. If not, I'll do the later model.
Thanks for the input.
Pete
Rjcapt
Post by Rjcapt »
I'm making progress slowly.
I got a 2000 swing arm and modified it to fit, reamed the case and welded in new mounts. I stretched the pipe 3/4" to fit and sent the carb/head and cyl out.
I still need to mod the KX airbox to fit the KDX boot, fab up the silencer and fit the 97 shrouds to the 01 frame.
I'm pretty happy with it at this stage, hopefully it will work well for me.
